Pistons? - Page 3 - Hot Rod Forum : Hotrodders Bulletin Board
  #31 (permalink)
Old 02-16-2007, 08:08 PM
xntrik's Avatar
Save a horse, Ride a Cowboy.
Originally Posted by hyarbour
I was thinking of going to a wide ratio 5 speed tranny to compensate for the 302's lack of low end and my 3.73 rear end should help, that and an offy cross-ram would diffinately be something nice to look at.
As for the pistons; I'll just get the right ones and some forged rods and proceed from there. I came across the pistons for $250-300, forged full floating type, still have to decide on what final compression ratio I want.
Thanks for everyones input
Howard
Howard,
If you are going to build a twister, you need lots of compression because of the long cam duration.
Watch out for pistons with more than .125 dome. The dome has a tendency to act like a fence and block the flame front of the combustion burn.
So deck height is important, squish/quench is important, and head cc's gives you your compression.
Yes you are going to need gear to get it going because the low rpm torque will be nil, but the power will also be peaky, so wide ratios might not be too good unless you spin it high before shifting. Calculate your rpm drop between shifts before you buy.
x
  #32 (permalink)
Old 02-17-2007, 08:59 AM
King of my Man-cave.
All this talk of using Ford pistons and oddball rods and such is just bench-racing BS. Make a small-journal 327 out of it. Find some 1.84/1.50 305 heads (depending on chamber size you will get between 9 and 10 to one compression.
tom
  #33 (permalink)
Old 02-17-2007, 02:33 PM
junior stocker's Avatar
See; what Machine Shop Tom said ,and what I said in my last post. I still think there's creativity left in this hobby and we all need to step out of the box once in a while. That's what HOTRODDING's about. BUTCH.
  #34 (permalink)
Old 02-18-2007, 06:54 PM
techinspector1's Avatar
Wiki Edits: 326
This was still buggin' me about the 327 pistons until I searched out a thread from 2002. It seems that Chevy built a 264 Gen II small block for the '94-'96 Caprice. The motor had a 3" stroke and 5.94" rods. Maybe the guy hyarbour got the motor from was trying to make a hermorphrodite 302 using 327 pistons and the 264 rods. If the block was 9.025" and the pistons were rebuilder types with a fairly short compression height, it could have worked out pretty close on the piston deck height. Depending on how much the piston popped out of the deck, a guy could run a little thicker head gasket to set the squish at 0.035".
Sorry Tom, more bench racing BS.
  #35 (permalink)
Old 02-18-2007, 08:42 PM
TechInspector1, The problem with the 5.94 rods would be the journal size;265-283-302 small journal crank and 327 small journal block, and spacers are only made for the mains if I'm correct. I still think based on his own discription of "hodge-podge" parts and mismatched heads the "327" piston was down in the hole. He never addressed that issue however; and, he seems pretty dedicated to the idea of building a 301/302. Can Howard come out and play? BUTCH.
  #36 (permalink)
Old 02-18-2007, 08:54 PM
Wiki Edits: 326
You're right Butch. I'm just trying to make sense of it and neglected to take the rod journal diameter into consideration. Thanks.
  #37 (permalink)
Old 02-18-2007, 10:54 PM
I've got a 3.1" large journal crank in storage waiting for a rainy day. It's out of a 262 or 267 I believe. It'll fit in a 400 block with spacers or the thick bearings and there are pistons available to work with a 6.125 rod. But I'm sure the rpm capability is low considering it's a cast crank. Sure would make for an odd combination though... I wonder what it would run like
  #38 (permalink)
Old 02-20-2007, 11:31 AM
re: Pistons?
Yes Junior Stocker; the pistons were farther down the hole than I would have expected, I was even considering using a 6" rod.
I'm just going to try and build up the short block to the Z-28 specs, use the 64cc heads I got with roller arms/cam and get an Offenhauser cross-ram. I don't really want to go over a 10:1 ratio because of gas prices for high octane.
As for using Ford parts in a Chevy; I think my truck would gag, not to mention the cost of all the machining involved. Come on guys, I think mixing Chevy and Ford parts could be a felony in Detroit.
  #39 (permalink)
Old 02-20-2007, 03:00 PM
No problem. You just have to separate the BS from the Shinola. Bench racing is fun until somebody's trick idea costs twice as much as the real deal should.
tom
Help with pistons sotxpanrider Engine 4 04-30-2005 12:29 PM
? about dome piston's bowtieorbust Engine 5 09-19-2004 07:34 AM
Long skirt SBC pistons fierosum Engine 9 01-16-2004 07:02 AM
Forged Rods and Pistons for Ford 302? Mustang 69 Chile Engine 6 10-21-2002 06:39 PM
