Pistons for 327 blower application - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 04-30-2013, 05:44 AM
Last journal entry: Accessories can drive you mad
Good heads are key on a blower motor! I run the Iron Eagle 200cc with 72cc chambers on a 355. Nice thick deck and doubt I will ever blow a head gasket. I am running 11psi boost and the car is pretty quick. If I had it to do over again, I would run the AFR's and get some weight off of the nose.
  #17 (permalink)
Old 04-30-2013, 08:28 PM
vinniekq2's Avatar
If you are choosing between a blower or good heads? The blower can wait.
  #18 (permalink)
Old 05-01-2013, 06:38 AM
Banned
I would argue for the exact opposite as forced induction can turn even the lowliest, most mundane engine into a real performer.
Heads definitely make an improvement too, but nothing like boost.
Heads, blower, and a cam would be an ideal swap combo though.
  #19 (permalink)
Old 05-02-2013, 10:01 AM
no exception for boost
  #20 (permalink)
Old 05-03-2013, 03:55 PM
mustang 671's Avatar
hey , been reading the complete thread firstly I have been where you are right now . about 6 yrs ago for me . battling with not great heads but have to have the 671 .
listen to f bird . I have read so many posts on forged pistons. don't go down that road. again the rebuild cost will be a lot higher when they brake. however if done correctly they will not brake . but make sure you READ the ring gaps on the kb pistons its CRUICIAL,
I have a thread going ( problems with running my supercharged 671 ) may be worth you reading it for 30 mins. lots of great info.
I have the 671 and will make 11psi boost with my puller combo. carbs then timing ,
you need good heads. don't listen to all that forced induction will cure cast head problems, I have seen a ls2 engine with tons of boost and not much horse power. a engine with lower boost and higher hp is flowing better. boost isn't everything. I bite the bullet and bought the edelbrock junior heads, kb hyper piston, mild crane street supercharged cam . and forged I beam rods. I have a +30 thou over bore and have 7.48-1 cr . its a very good combo with a low cr , you can be very safe with that cr - water meth inj is a must. good timing is a must. I opted for ecu and ditched the dizzy. as I can programme in knock sensors and all sorts of other warning triggers that will turn off the engine hrs before I get to hear or see the fault
but if budget is a issue then go safe. build it slowly ( its my 11th year and nothing broken yet ) research research research
listen to f bird . he calls a spade a spade , and will tell you how it is. there are also some other great people on here with some other advise that is very good aswell. I have had some great info. so please read more and research more before you choose. as its going to be expensive if you don't as you say you want to gain the experience, so don't learn by your mistake's. as with a blower its
The Following User Says Thank You to mustang 671 For This Useful Post:
67-4-fun (05-03-2013)
  #21 (permalink)
Old 05-03-2013, 11:51 PM
Right on yeah been exchanging pm.. I'll take a look at your thread. One way to learn is to do it.. You screw up you learn and fix it and move on..
327 471 blower 7.5 comp. pistons which heads for street Eddy O. General Rodding Tech 2 01-27-2012 11:38 PM
what is the best 383 stroker kit for a blower application vcb Hotrodding Basics 5 05-22-2011 08:07 AM
need help with blower pistons malibu68 Engine 3 01-19-2007 10:32 PM
Can street carbs me modified for blower application? blownS10blazer Engine 3 07-19-2006 02:26 PM
blower pistons ??? singletoncamaro69 Engine 9 04-02-2004 08:02 AM
