Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Pistons?
Thread: Pistons?
Old 02-14-2007, 02:41 PM
xntrik's Avatar
xntrik xntrik is offline
Save a horse, Ride a Cowboy.
Originally Posted by hyarbour
Hi guys,
I bought a 327 for rebuilding to put in my truck. While the block was a 327, the rest seems to be a hodge-podge of whatever the guy could get his hands on; for instance: 60cc heads on one side with 70's on the other and a 302 crank.
Right now I need to figure out the pistons, the only marks on them are 740P on the inside. They look fine, but are they for the 327, a 302 or a 350? Did those engines have different heights from the pin to the piston top or was it one size fits all?
The pistons are flat tops with reliefs and look fine; can't really tell if they're cast or forged, but I'm guessing cast. Has anyone ever come across these ones before? Any help would be appreciated before I buy a new set for new reason.
If it is a 302 crank, then it is not a 327 cube engine.
If you intend to use that 3.00 stroke crank you will get a 302 to 310 cubes, and you need 302 parts.
