Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Pistons dont fit in block.
Old 02-28-2013, 09:10 AM
prumora1 prumora1 is offline
just like other post stated you need to file fit the rings, unless they are gapless, there should be a paper with your rings that give you the equation for figuring on your gap. it will have a multiplier for different applications such as street, racing, supercharged and even your types of fuel you plan to use.
all of these things make a difference when your putting your motor together. also there is a top and bottom to the rings, the top will be indicated by either a dot or a taper on the ring its self
