Pistons dont fit in block.
Hello i decided to re ring my chevy 350. I honed the cylinders with 400grit stones and bought new sealed power moly rings ze251k, now i tried to install the pistons in the block but couldnt. i bought the piston ring compressor and applied light oil to both the piston skirts and cylinders.
I noticed that piston stopped at the second compression ring. I hit it alittle hard and forced all the piston in but stopped, i didnt want to break anything. I then decided to pull the piston out. now there is a grey mark on the cylinder wall were the piston rings were. I made sure i had boots on the bolts and not hitting the crankshaft. Also i made sure the rod wasnt hitting anywhere. And there was plenty of oil on these parts. Help is really appreciated. |
Sounds like your rings are too large....Try a ring in the bore by itself, without piston and see what the gap is at the end of it
Most after market piston rings are 'file to fit'. To say that, they are manufactured .015 to .020 oversize to fit differences in the way each cylinder is bored.
I don't have photos handy, but you take each cylinder individually and each piston (I use that cylinders piston) and a set of the three rings that you intend on using in that cylinder. I then push the top two, one at a time, about an inch into the piston bore, using the top of the inverted piston itself and measure the end clearance with a feeler gauge. This should end up being be.005/.007 per inch of piston diameter(4" piston would be .020 gap) for the top two rings AFTER YOU FILE TO SIZE. This may entail several 'trips' into that cylinder and several passes with a file or special filer tool (Summit and others will have that tool). The bottom and usually 3 piece ring doesn't get any fitting (normally) and is installed as supplied. There are many write ups on the internet, but if you have conventional cast/moly rings, will all use this kind of assembly. There are other kinds that are installed differently, but are specials with those 'special' high buck prices. Dave W |
251k rings will not fit GM factory pistons. Factory pistons require a "Shallow groove" ring. Consult an automotive machine shop or REAL auto parts store for correct cast iron ring set for the different VIN codes.
ok guys so i decided to go with cast iron rings. would i need to re hone the cylinders?
No, cast rings are very forgiving. Thats why they are used in worn bores. Never Chrome or Moly!
so what rings would you guys recommend??
Sealed Power, Hastings, Perfect Circle, Mahle, are all quality stuff. Cast iron for best results in your situation.
Pistons don't fit block. Help
It is probably worth mentioning that you need to ream the ridge off the top of the cylinders. If you put new rings on and leave the ridge, it will break the new rings.
i seen this thread is a bit old but if ur tryin to put them in a 350 it not gonna work thats a 4.00 inch bore. l2477 pistons are for a 400 small block whitch has a standard bore of 4.125 hope that helps ya out.
just like other post stated you need to file fit the rings, unless they are gapless, there should be a paper with your rings that give you the equation for figuring on your gap. it will have a multiplier for different applications such as street, racing, supercharged and even your types of fuel you plan to use.
all of these things make a difference when your putting your motor together. also there is a top and bottom to the rings, the top will be indicated by either a dot or a taper on the ring its self |
| All times are GMT -6. The time now is 02:58 PM. |
