Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Pistons dont fit in block.
Old 10-07-2012, 07:48 PM
cdminter59 cdminter59 is offline
Pistons don't fit block. Help
Originally Posted by darce View Post
so what rings would you guys recommend??
Check your piston on the inside for a number. Call Hastings or Speed Pro with the number. They will tell you the correct ring part number. Is the number #10128249, and have 6106 on it? If it does it uses Hastings #5615.
