pistons/heads cleaning? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-08-2007, 11:22 PM
montea's Avatar
tryn to learn
i pulled my SBC 350 apart to put new gaskets in it and im just wondering if i should be cleaning the piston tops and heads before i put it back togther. the motor has 10,000km(6,000miles). heads were new but pistons were reused when it was rebuilt. i attached a couple pictures, they seem to have a fair amount of carbon on them for a motor that wasnt lightly used? is my carb running to rich?
Old 03-09-2007, 01:33 AM
montea's Avatar
tryn to learn
oops forgot the pics
ID:	19306   Click image for larger version
Old 03-09-2007, 04:24 AM
Guy Hiltz's Avatar
piston/heads cleaning?
Personally I would clean everything and also smooth any rough edges,although the black build up will probably return.As far as I know a build up of carbon like you have is normal.
Old 03-10-2007, 11:59 AM
bondo's Avatar
Well,.......
You Could have Cleaned the combustion chambers Before you tore it down,......
Or,.....
You can Still do it the Easy Way,...... After you reassemble it.......
If you were to reassemble the motor, cleaning the gasket surfaces as required,....
Then Fire it Up,+ run it til it reaches operating Temp......
If you Rev to motor to about 1500/ 1800rpms,+ Slowly pour about 16oz. of Water straight down the Carb Throat into the motor as it's running,......
Pour it Fast enough to Labor the motor, but not so fast it Stalls.....
The Combustion Chambers will be Spotlessly Clean......... Steam Cleaned if you will...
I do this to any motor that I know needs to be torn down.......
Gas, Diesel,... It Don't Matter........
It sure beats Scraping,+ Chipping the Carbon.......Alot less chance of a Bad Scratch somewhere as well......
Fuel Tank cleaning 65Stanger Engine 2 05-07-2006 05:41 PM
Cleaning, boring, painting...383???? Hazard Engine 14 04-14-2005 10:00 PM
Cleaning electrical contacts Kevin45 Electrical 0 01-05-2003 10:22 AM
Block / heads cleaning tips DoubleVision Engine 6 10-25-2002 02:47 PM
