Pistons hit heads on 454 w 25.5cc dome - Page 3 - Hot Rod Forum : Hotrodders Bulletin Board
  #31 (permalink)
Old 08-26-2011, 09:38 AM
check out this 454 build.
http://www.superchevy.com/technical/...ild/index.html
565hp with 8.25:1 cr, cheapo summit flat tappet hydro cam and stock pistons.
Then 736hp with a little 150hp shot of NO2.
all for $2500.
You don't need that big a cam or that much compression. 9.8:1 is enough for a 454 and a cam with around 250 degrees duration at 0.050" lift. Should be able to make more hp than you can stick down on the ground.
that with a 3500 stall, 4.11 gears, in a lighten nova should get you easily in the low 11's at 120mph
  #32 (permalink)
Old 08-26-2011, 01:28 PM
TonkaYJ's Avatar
Last journal entry: Took her out for a drive Oh Ya! Gotta Love an LS powered early Vette
Thats a nice build but I want alittle more we have decided to rebuild it from scrtch its going to get all remachined new rods and pistons all new berrings re ballance convert to 4 bolt main push rods rework the heads all new valves springs retainers and locks push rods and new timming set new gaskets $4500. I have said Go I fell thats a good deal with the rep yhe shop has
  #33 (permalink)
Old 08-27-2011, 11:18 AM
good luck with those heads. i would be using a stud girdle also , I had same problem I removed a little of the heads so sparkplug would clear. with a .640 lift flat tappet no girdle broke the stud boss out of the head the casting looks very porus on the inside and these heads are around 5lbs lighter than any other al. head. Just fired mine up today with a set of steel 188's no more procomp for me . there combustion chamber is different than stock is why you hit.
  #34 (permalink)
Old 08-27-2011, 11:39 AM
TonkaYJ's Avatar
we are using a stud girdle it is recommended to use one with my cam, The castings were the only part or the pro comp heads he was ok with using he also said the assembly was very poor and would not have worked with even a smaller cam. I would never buy another set I traded a better set of heads for them I had a set of 69 427/454 rectangle port aluminum heads that needed valves I traded for this set
  #35 (permalink)
Old 08-27-2011, 11:42 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Tonka- an option is to sell the PC's on ebay and buy yourself a set of Profilers.
  #36 (permalink)
Old 01-07-2012, 08:43 PM
TonkaYJ's Avatar
Well my motor is done and I cant wait to get it in the car I ended up spending a lot more money than I planed but I think the end result will be worth it so what we have now is block was All re machined converted to 4bolt main 60over
JE pistons eagle rods all rebalanced Heads were all re machined for new valves springs retainers ect I had him assemble the whole thing I need to go get some valve covers and a low alt. mount a set off flex plate bolts and converter bolts and she is ready I think I may have to sneak off to the parts store before my wife gets up
  #37 (permalink)
Old 01-07-2012, 09:13 PM
matts37chev's Avatar
I don't understand?
Last journal entry: this is only a test
glad you got it done
same cam? that was a lot of cam
  #38 (permalink)
Old 01-07-2012, 10:17 PM
TonkaYJ's Avatar
Yes same cam,& compression went up to 13.5 Its going in a 68 Nova right now I also have a 37 Chevy coupe That i am building some day this motor will go in it . I am doing a Jegster Chassis kit on it now.
  #39 (permalink)
Old 01-08-2012, 07:34 AM
I don't understand?
thats cool
It would be great if you shared some pics of it, in this 37 & 38 chevy thread I'm getting started
I would really like to see it
  #40 (permalink)
Old 06-03-2012, 10:00 PM
TonkaYJ's Avatar
Took it to the track ran a 10 sec pass firt time out
Well I got the car running I took it to the track ran several laps at 3/4 throttle (cable and bracket issue) car runs sweet I just need to learn how to drive it. Thats my buddys 63 nova I am racing it felt very good to pass him ran a 10.48 cant wait to see how it does on fresh tires and full throttle
http://www.youtube.com/watch?feature...&v=rjikEbXqplI
  #41 (permalink)
Old 06-04-2012, 07:14 AM
Nice work. Nice car. Post up your first 9 second slip.
dome pistons vs. flat top philr Engine 24 12-15-2012 01:50 AM
Dome Pistons and spark plugs DeathRattle Engine 8 11-06-2006 04:06 PM
Anybody make dome pistons to work with Vortec heads? dirtracerx Engine 3 09-09-2006 09:05 AM
vortec heads and dome pistons blazin47 Engine 14 10-03-2005 07:56 PM
Looking for inverted dome pistons for 400 sbc Chevy21 Engine 10 08-04-2005 07:20 PM
