-   -   Pistons hit heads on 454 w 25.5cc dome (http://www.hotrodders.com/forum/pistons-hit-heads-454-w-25-5cc-dome-204179.html)
TonkaYJ 08-23-2011 09:05 AM
I have asked before about this motor but now I wanted to check my valve to piston clearance I found I need push rods and the piston hits the head close to the spark plug hole. How and how much can I remove from piston? are the valves going to hit as well? what push rods? I have KB 25.5cc dome pistons.Pro Comp 320cc heads W/ 115cc chambers. Lunnati 722 lift roller cam Please has anyone run this combo? what do I do now?
68NovaSS 08-23-2011 09:15 AM
Being a blower motor guy, I don't get into dome pistons much, but can't imagine them hitting the head in a 115 cc chamber, but anythings possible. Looking at the obvious, are the pistons installed/oriented correctly? I'd be leery of removing too much of the dome and compromising the piston head thickness.
As far as valve clearance, which pistons are they, single, double valve reliefs?
TonkaYJ 08-23-2011 09:38 AM
KB257 Pistons. Cam is solid roller Lunati 50226LUN.rockers are crower 1.7 rollers. Heads are Pro Comps as said before seam like they just bairly hit it will spin and only 2 piston have a mark #s.5&6 . I searched and found very little info. I found this is not so un common as brodex has a little info about it. They say to clearamce the piston. They also say it will not bother my ballance because its above the piston pin? Is this true? will this work? there is a notch in the piston that seams to be for this but its off a little one way I will try to post a pic later
http://i427.photobucket.com/albums/p...0823085639.jpg
TonkaYJ 08-23-2011 10:13 AM
bump for pic
loudandproud 08-23-2011 10:26 AM
it "will" affect the balance of the piston. But its gonna be negligible because of the distance from the pins center plane. That said, how thick is the piston at that point?
Id take a little material from both the head and the piston before i took of a fair amount from one.
Throw that sucka on a mill and start cuttin...
lmsport 08-23-2011 02:44 PM
Check the stroke of the crank on the 5 and 6 pin.
68NovaSS 08-23-2011 03:14 PM
Is it just an illusion or is that piston out of the hole, above the deck?
TonkaYJ 08-23-2011 03:46 PM
crank was checked by 2 good engine shops
TonkaYJ 08-23-2011 03:47 PM
Just the dome is
lmsport 08-23-2011 04:24 PM
Thats an unusually random problem. Did you use the same head to check both sides?
cobalt327 08-23-2011 04:38 PM
Use clay and check ALL the chambers. Just not seeing a mark on the piston doesn't mean the other domes couldn't be just a hair away from touching. Mark the heads "left" and "right" and keep them in the same position.
TonkaYJ 08-23-2011 05:17 PM
I sent everything to a machine shop that builds a lot of race motors around here I asked him to make it fit and degree the cam and figure out what push rods I need so we shall see what he says
cobalt327 08-23-2011 05:27 PM
Thanks for the update- that's sure one way to deal w/it! lol
Keep us posted...http://www.powerstroke.org/forum/ima...s/popcorn2.gif
TonkaYJ 08-24-2011 08:08 AM
I will let ya all know what they do. I am just wanting to get it running and at this point I figured let a pro look at it
TonkaYJ 08-24-2011 03:56 PM
OK pistons clear heads after trimming piston dome edges now with cam degreed in the intake valve has only .050 and the exhaust has 108 the intake valves are to short to set up and he says I may not have enough compresion for the cam what to do now ? he wants to think about it overnight and get back to me what do you guys think
