-   -   Pistons and rings cracked (http://www.hotrodders.com/forum/pistons-rings-cracked-218885.html)
chevy355ss 05-01-2012 07:24 PM
I just finished rebuilding a sbc 350 which had a problem with extreme blow by coming out of the valve covers...tore engine down to find 4 pistons (#1,5,8,6) had cracked ring lands, rings, and #5 cam side skirt broke off. Engine was .03 over and I had originally put std rings so I gave the damage up to that...Finally get the rebuilt engine with .03 rings and pistons (hypers) and only about 40 miles later the same extreme blow by coming from valve covers....Have not had a chance to do any tests or tear into it to see what is causing it this time but I have a pretty good feeling its either the rings or pistons cracked again....I am completely stumped as to wy this is happening....Any suggestions??????????
BOBCRMAN@aol.com 05-01-2012 07:33 PM
Wrong pistons/heads, wrong timing, wrong gas, pre-ignition, overheat. one or more of the above..
68NovaSS 05-01-2012 08:21 PM
Are rings file to fit? What were your end gaps?
zildjian4life218 05-01-2012 08:26 PM
Sounds like to me the rings were too tight and butted together and when they have no where to go they will crack the ring lands. Did it happen again? Idk what did you set the top and second ring gaps to?
cobalt327 05-01-2012 09:30 PM
There are KB hypereutectic pistons that need more top ring gap than 'normal'. If you have a set of those in it and the gaps were set the way a cast piston is usually gapped... :pain:
AutoGear 05-02-2012 08:53 AM
Im with Cobalt. I remember getting the KB Hypers years ago and they had a little paper flyer in the box that specified the 'odd' gap.
My friend bought some of the same pistons via the internets; no paperwork. He set up a conventional ring pack and cracked or distorted the ring lands in all 8 pistons.
Why only 4 pistons though. You may have several problems manifesting themselves here. Did you check for interference with the valves? Was the block decked? Heads shaved? What is your compression ratio and what fuel are you running. What are you using for timing?
you might want to post your assembly procedure for us to look at. Not to judge, sometimes we miss a step.
zildjian4life218 05-02-2012 10:16 AM
Does anyone know if the KB-231 require this larger ring gap? Thats what I have in my engine and have had ring seal issues with it.... i just wanna rule this out.
cobalt327 05-02-2012 11:16 AM
http://www.kb-silvolite.com/assets/a...ve_catalog.pdf
BigEd36 05-02-2012 02:35 PM
1 Attachment(s)
Here's the KB ring end gap guidelines, this should make it pretty easy to figure what your ring end gaps should be:
chevy355ss 05-04-2012 07:16 PM
Sorry havnt got a chance to get on here lately....new in the engine building area and did not know about having to check the ring gap ooops....thinking back they did want to go in pretty hard so im thinking the rings needed to be filed to fit just right and ended up cracking on the way in.....hoping to have it tore down next week sometime and i'll let you all know what i find
Thanks for the responses they really helped!!
