Pistons and rings cracked
I just finished rebuilding a sbc 350 which had a problem with extreme blow by coming out of the valve covers...tore engine down to find 4 pistons (#1,5,8,6) had cracked ring lands, rings, and #5 cam side skirt broke off. Engine was .03 over and I had originally put std rings so I gave the damage up to that...Finally get the rebuilt engine with .03 rings and pistons (hypers) and only about 40 miles later the same extreme blow by coming from valve covers....Have not had a chance to do any tests or tear into it to see what is causing it this time but I have a pretty good feeling its either the rings or pistons cracked again....I am completely stumped as to wy this is happening....Any suggestions??????????
Are rings file to fit? What were your end gaps?
Horsepower is how fast you hit the wall. Torque is how far you take the wall with you. Midnight Sun Street Rod Association |
Sounds like to me the rings were too tight and butted together and when they have no where to go they will crack the ring lands. Did it happen again? Idk what did you set the top and second ring gaps to?
There are KB hypereutectic pistons that need more top ring gap than 'normal'. If you have a set of those in it and the gaps were set the way a cast piston is usually gapped...
Does anyone know if the KB-231 require this larger ring gap? Thats what I have in my engine and have had ring seal issues with it.... i just wanna rule this out.
Sorry havnt got a chance to get on here lately....new in the engine building area and did not know about having to check the ring gap ooops....thinking back they did want to go in pretty hard so im thinking the rings needed to be filed to fit just right and ended up cracking on the way in.....hoping to have it tore down next week sometime and i'll let you all know what i find
Thanks for the responses they really helped!! |
| cracked block or cracked heads | 4x4Chevy | Engine | 12 | 01-18-2012 03:41 PM |
| pistons,rings&bearings will it be hard? | cutthroatkid | Engine | 1 | 10-29-2009 03:56 AM |
| file fit rings or std. rings | dboyett38666 | Engine | 21 | 03-20-2006 07:32 PM |
| Can you use oversized rings in stock pistons | stonedchihuahua | Engine | 4 | 12-06-2002 06:30 PM |
| Cracked piston rings!! | tjk2000us2000 | Engine | 4 | 08-03-2002 09:52 AM |
