Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Pistons and rods for sbc 350 ?
Old 09-23-2012, 09:58 AM
vinniekq2's Avatar
vinniekq2 vinniekq2 is offline
The dual plane intake Vs vic is debateable. I choose open plenum intakes for my type of driving. Piston question has been answered.Get rid of hei and use a multi spark unit with a rev limiter. If a driveline part ever breaks at w.o.t. then the engine is safe.10:1 compression is a good goal to achieve with aluminum heads and 91 octane. I use 10.75:1 and I can get 94 octane at the pump.If you no longer use the car on the track then the dual plane will respond better at low rpm. fuel injection is much better for off road.
