Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Pistons and rods for sbc 350 ?
  #22 (permalink)
Old 10-11-2012, 07:32 PM
Icejeep Icejeep is offline
I like this plan, except that this engine must run on 93 oct pump fuel so i belive 12.5:1 compression is out of the question. I also would like to use flat top piston in this engine, or at least with as small dome as possible. Camshaft will ofcourse be solid roller. Just haven't decided if i should go with wilder one then this i have now... Everything else is pretty much sorted out though !
Best regards.
