Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Pistons and rods for sbc 350 ?
  #27 (permalink)
Old 10-13-2012, 11:35 AM
F-BIRD'88's Avatar
F-BIRD'88 F-BIRD'88 is offline
Yada Yada Yada
Hell you can drive this to work and back its so simple.
Looks fine. Consider the street tunnel ram intake .
A example of the base line roller cam for this would be
a Comp #12-911-9 (but could be ground on a 108LSA)
I want you to :
Call Comp Cams or your favorite camshaft grinder to get set up.
The 4.10's are fine for getting a base line and a good compromise for Nitrous.
if the exhaust headers are dinky street headers (the outside diameter is 1-5/8" and the inside diameter is less)
You can step that up.
