I like this budget solution for the fuel system, as it's set up now i'we got one 6 gallon cell in the trunk and one Holley Blue pump that pumps through 1/2" line into Holley fuel pressure regulator that has two 3/8" lines that go to the Carburetor. Would this system compensate for the dual Carter set up on the motor alone ?
How high do you think i need to spin a motor like this ? |
(and it will) replace with the carter pumps. (move the fuel cell to the front too) You will be shifting at 6800-7200rpm. The 4.10's will keep the motor from excessive rpm thru the traps. No worries. 350's like to rev. The motor will show you what it likes. Comp Cams will help you get the valve train right. Thats why you need to call them . A cam in this area will work very well for you in this car. Don;t get greedy with the nitrous shot on pump gas. This car is going to GLH on a true 150HP shot on the T ram. Step up to 110 octane unleaded to play with the big shots. Get a spark control box and a nitrous RPM switch. No rev limiter is required for this simple combo. Shorter slick for N/A... taller slick for Nitrous. Keep it simple. Last edited by F-BIRD'88; 10-13-2012 at 01:06 PM. |
Thank you for all your advice sir. I will contact some cam company's / grinders during next week and then i'll let you know how things work out.
I remember that with the small street roller cam, 2400 stall holeshot converter and 4.10 gears it would go through the traps at 5700-5800 rpm at 117-118 mp/h. It was slow of the line but still i found that it would finish the first gear at 6500 rpm shifts very quickly. 60 ft times were only at flat 2.0 seconds. Hopefully i will do better with my new high stall converter. Thanks again ! Last edited by Icejeep; 10-13-2012 at 01:14 PM. |
I needto measure up the port size of the head and then the opening of these headers. Will post the results here when i'm finished !
But i did ran it like this with the low compression and small roller cam and it did just fine i think, wasn't laying off anywhere in the powerband and spun very quickly and easily to 7000 rpm's But i agree with you they might be bigger these headers. Maybe 1.3/4" headers should do the trick ! |
| Pistons and connecting rods for a 406 SBC | Laird006 | Hotrodding Basics | 5 | 09-28-2012 09:44 PM |
| 350 sbc pistons | Thumpr | Engine | 5 | 09-08-2009 05:02 PM |
| 350 to 383, works with my 350 rods and pistons? | Berres | Engine | 2 | 07-27-2009 07:51 AM |
| Questions on floating or pressed fit pistons and rods for SBC 350 | eric32 | Engine | 4 | 01-30-2009 04:19 PM |
