Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Pitman Arm
Thread: Pitman Arm
Old 03-19-2010, 09:16 PM
for3300 for3300 is offline
Hey thx for the info man, I think mine could stand to go up a little further, the threads of the new gear box aren't even exposed right now, and I cleaned the pitman splines before putting it on the new steering box....on a side note have you ever had an issue with power steering fluid leaking from the pressure line where it connects to the into gearbox? mine is leaking from the point where the metal line goes into the threaded part of the hose, I have tightened it as hard as I think I can get it.
