pitman arm ?? - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-23-2009, 12:59 PM
pitman arm ??
So I bought a salvage yard power steering box for my 1977 nova. The car came with a manual gear box. The pitman arm on the power gear box is 3/8 to 1/2 an inch longer then the original on the manual steering box. Everything seems to be visually ok. Is there any type of performance issue here? Everything seems to turn and move freely I just dont want to have a safety problem if I leave the slightly longer arm on.
Old 10-23-2009, 04:45 PM
Last journal entry: frame build
Will give you a little faster and a little heavier steering steering. As long as it will still self return to center when you loose the wheel, no problem.
Old 10-24-2009, 02:12 PM
No, this is a bad combination. The pitman arm and idler arm MUST be the same length. You can't change one without the other. Either change the idler arm to match your pitman arm or put the manual pitman arm on the power box.
Old 10-24-2009, 03:18 PM
ericnova72's Avatar
More for Less Racer
I don't believe the manual pitman arm will fit on the power box, the output shaft sizes and spline counts are different(they were on my '72 Nova). You will need to get the correct length idler arm.
Old 05-01-2010, 06:51 PM
steering gear box salvage
I replaced my steering gear box with one I bought from a salvage yard called pull apart. I got it for $42 and it is working great.
Old 05-01-2010, 07:03 PM
I dont think he hooked it up because i believe it wont work. Geez i took my power steeing out for manual steering ,lol.
pitman arm question bigfred1958 Suspension - Brakes - Steering 3 09-10-2009 09:04 AM
early Mustang pitman arm user151 Suspension - Brakes - Steering 3 05-11-2009 08:55 AM
bending a Vega pitman arm Slomotion34 Suspension - Brakes - Steering 29 08-01-2008 08:05 AM
Custom Pitman Arm Tribal Suspension - Brakes - Steering 7 07-17-2007 04:24 PM
Header Clearance Issues with Pitman Arm k2mooch Suspension - Brakes - Steering 4 04-26-2005 01:35 PM
