pitman arm clerance - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-15-2003, 04:14 PM
New Member
Post pitman arm clerance
I have a "38 Ford with 4" dropped axle and reverse eye spring for a 5" dropped. Now the pitman arm is too close to the ground. Can I bend it up? Someone said an arm from a '36 would work because it's shorter. Any Ideas?
Old 03-15-2003, 06:23 PM
BOBCRMAN@aol.com's Avatar
Post
yes you can bend it up,in the old days we would heat it up till red then bend, then let it cool real slow,
Old 03-15-2003, 07:35 PM
willys36@aol.com's Avatar
Wiki Edits: 21
Post
What Bob said. Forged suspension parts like steering arms can safely be heated red and bent then cooled VERY slowly. For sure, don't quench in water and don't even blow air over it.
Old 03-16-2003, 09:04 AM
adtkart@aol.com
Post
If you have lowered the front that much, chances are thet the geometry is incorrect on that car. Generally the tie rods and center link should be paralell to each other and the ground. You should make the adjustments to keep that correct, not just the ground clearance.
