Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Pitman Arm and drag link location
Old 01-02-2011, 03:48 PM
NEW INTERIORS NEW INTERIORS is offline
life is a temporary assignment
Originally Posted by hotwheels1
It was brought to my attention yesterday that my pitman arm and drag link may be at to much of an angle. If i were to flip the pitman arm, it will hit my firewall when i turn....I had to move everything back do to the stock manifolds for the ford 400 engine exhaust manifold.....You all have any thoughts on what i should do here? Is the current angle okay, or should i try to cut into my firewall and flip the pitman arm?
You may be OK.. Might have a little bump steer.. You can't flip the Pitman arm.. It will turn the wrong way.. You need to make sure what way it is turning now..
I have never set one with that much angle.. You may have to try it.. Just watch you from end don't go into a death wobble.. I have seen some on some real good angles already..
