i am having trouble installing my pitman arm. is there some special way or tool to install the pitman arm on the steering box. this is for a 73 nova.
thanks,
mike
If it is the right one, it should slip right on and tighten the nut good.
Troy
If you don't make mistakes. your not doing anything.
69 ss rs full custom camaro 98 ISCA grandchampion
69 ss rs bb camaro wifes driver
66 Elcamino 350/all dz parts,ac,windows,loaded,my driver
69 ss chevelle bb conv.fresh frame off
26 T sedan street rod
but when i am tightening my piut man arm it moves the steering wheel all the way to one side to where it will not go any further and i am afraid that tightening it more will break the steering box because it will be forcing it more in that direction when it is at it's max. i thought the pitman arm was supposed to be pressed on or something, it goes on about half way but then it is hard to push on the rest of the way. everything is new also.
thanks,
mike
Sounds like it is fitting alright, have someone hold the steering wheel. The steering wheel should be locked anyway.
torque to 140 lb. ft.
Troy
ill try it, just bought the steering box and didnt want to ruin it by tightening the pitman arm wrong.
thnks,
mike
Related Threads
Hot Rod Forum
2.2M posts
175.7K members
Since 2001
