if it was mine , like i did on my 68 cougar. wire wheel it clean, shoot it with epoxy primer, then depending on how deep the pits are use dolphin glaze to smooth it up , followed by a filler primer. i used all kirker paint products on my car and so far very pleased.
yes the epoxy primer will seal the metal.
Be very careful leaving rust in the bottom of those pits--it could cause you problems in the future even with epoxy.
Unfortunately, the only way I've found to be sure you're getting all the rust is to sandblast. So, it's kind of a risk/reward calculation. Make sure you scuff the epoxy before laying down the filler. Also, if you have a lot to do, I find thinning regular filler works pretty well. Good luck! |
What about using Klean Strip's rust converter on the rust left in the bottom of the pits? Is this stuff any good.....it says it turns rust into primer....SO, does that mean after you apply it and it dries,you can paint it? Actually......How does this stuff really work or whats the proper way to use it?
Thanks GM |
you can use metal to metal body filler on that. Afterwards go on with good 2 part filler primer like PPG K36
don't use a rust converter . clean as much of the rust off as possible. seal the metal with a good epoxy primer and paint. the only true way to beat rust is to cut it out and replace with good metal. other wise you can fix it now and then fix what could be a worse problem later.
but in the end its your project , you know your skills , your budget and what you need to do to sleep peaceful at night with out staying awake listening to rust eat your car.
O.K.,NO rust converter
Check.Sand and wire wheel, Check and seal with good epoxy primer I may be seeing a sandblaster in my near future but for now its sand paper and wire wheel.What is a good epoxy primer to use? I know PPG make good stuff but I dont want to limit my options to picking one because they are the most expensive.....I would rather pay for the quality of a product rather than just its name on it.... |
iam useing kirker products on my 68 cougar and have found them to work great so far and reasonable priced. i got them through auto body tool mart online.
Thank you guys for all the posts....I appreciate the tips
Now what would be a good spray gun to use with epoxy primer? I was thinking about getting a hvlp so I can try my hand at painting later,with the primer being thicker I have read people using 2 different guns, one with a bigger nozzles for the primer .....is it possible to use the same gun for both and get different sized needle/nozzle for each(paint/primer)? or better to buy 2 different ones? Thanks again GM |
O.K., I found this http://www.finishsystems.com/qanda.html
Its like a little beginners guide for..................UM, beginners Thanks GM |
| sand and primer question | APACHEMAN | Body - Exterior | 6 | 02-18-2009 09:03 PM |
| Question about factory replacement parts and primer | makaveli200369 | Body - Exterior | 2 | 05-01-2006 08:40 PM |
| Question abour factory replacement parts and primer | makaveli200369 | Body - Exterior | 11 | 04-30-2006 09:24 PM |
| spri primer shipping question, clear gooo on containers | pigman | Body - Exterior | 8 | 08-23-2005 10:32 AM |
| New guy, primer question | Cougar68 | Body - Exterior | 3 | 03-17-2005 11:04 AM |
