Pitted aluminim wheels - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-19-2009, 08:57 PM
I have an older set of Ultra wheels for my chevy. They are pitted. How can I remove the clear coat on the wheels or can i do any thing to improve them.
Old 04-21-2009, 09:17 AM
well if you have the time you can polish them. aluminum can be treated much like paint. start by sanding them with 1200 then 1500 then 3000 if you really want a good shine. once the sanding is done get a good buffing compoun and buff the wells until the shine shows through. they will stay polished for a while about like a polished intake. year one also have bare metal clearcoat if you wanted to go that rout. good luck
Old 04-21-2009, 09:56 AM
boatbob2
clear coat removal on wheels..
HI,i wanted to clean up a set of clear coated wheels,so i used engine cleaner (gunk) and it took off the clear coat on 1 wheel. (i didnt want to lose the clear coat)on badly corroded wheels,you can water sand,starting with 280 or 320 grit,BUT,this will be quite a project.then go to 600,1000,and finish up with either 1500 grit or 2000 grit. then finish up with MOTHERS ball and compound.
Old 04-21-2009, 11:14 PM
I got the clear coat off my Jeep wheels with paint remover. Came off pretty easy with a wood scraper so I didn't scratch the aluminum.
beware whiteys wheels Dainleljedal06 Off-Topic 7 08-17-2008 06:48 PM
need help on wiki article: pitted rust Jon Body - Exterior 4 08-07-2007 09:38 AM
Ford Steel Wheel Tech wheelkid General Rodding Tech 9 01-07-2007 06:31 PM
Questions about wide wheels and fender flares tcruise Body - Exterior 5 06-09-2006 05:50 PM
Beware Coddington Wheels! 37cabriolet General Rodding Tech 18 12-24-2003 09:24 PM
