Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - pitted frame
Thread: pitted frame
Old 12-20-2012, 11:28 AM
John long John long is offline
The problem with not filling the pits is this. It will look good until it leaves the garage and is driven. If you don't get the frame, and components, slick it is absolutely impossible to wash it and keep it clean. A rough or pitted frame will become an eye sore very quickly and really shows under a restored car that sits high off the ground.
I have never seen body filler, All Metal, or high build primer fail on a properly prepared chassis. Any will work depending on the depth of the pits. I suspect if this is an unrestored car that a body filler over epoxy would be the best and most cost effective. Post some pictures as you go.
The Following User Says Thank You to John long For This Useful Post:
peteandrepete232 (12-20-2012)
