Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Pitted Metal On Winshield Frame
Old 11-15-2005, 08:54 AM
roger1's Avatar
roger1 roger1 is offline
Originally Posted by RICHARD MORGAN
Should I use the por patch stuff to fill in the "pits"? When I used the rust removing wheel I grinded away the paint about 2" past the window gasket. If I brush on the epoxy primer will the future painter of the truck have issues with any brush streaks? Should i use one of those little 3" rollers? Or can he just simply just sand them out?
I wouldn't use the por product.
In the area past your window gasket, I would use a polyester glazing putty (spread like bondo) over the sanded epoxy and then block sand the glazing to smooth out the surface where those pits are. Then spray a 2K urethane primer over the glazing and do a final blocking.
(Sandpaper wrapped around a paint stirring stick cut to about 3 inches long works well for blocking out small areas like this.) Block your glazing with 120 then 180 grit dry and your urethane primer with 400 wet.
