Pitted Metal On Winshield Frame - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-15-2005, 06:21 AM
After removing my windshield I found allot of surface rust. I used a 3m "rust remover" wheel on my drill and then soaked the frame in naval jelly. Now I have have clean but pitted metal. What should I do next? I have allot of supplies to work with. I have some ppg epoxy primer, por-15, por patch, and some rattle cans of eastwood's rust Encapsulator. I was thinking of using the epoxy primer, then the por patch to fill the pits, and then top coating with another coat of epoxy primer. Is this the right procedure or should I try the por 15 paint?
Old 11-15-2005, 07:07 AM
roger1's Avatar
If any of those pits still have black rust in there, use more naval jelly and get it out with your wheel. Poke the pits with an awl and make sure you don't have any holes. If you do, weld them up with a mig and grind flat. Then sand the area with 80 grit paper and coat with 2 coats of epoxy primer. (You can brush it on.) Then re-install your windshield. I recently did this and used the SPI epoxy primer. It is good stuff.
And,btw, MartinSr posted a real good windshield install how-to in the FAQ's.
Old 11-15-2005, 07:36 AM
Should I use the por patch stuff to fill in the "pits"? When I used the rust removing wheel I grinded away the paint about 2" past the window gasket. If I brush on the epoxy primer will the future painter of the truck have issues with any brush streaks? Should i use one of those little 3" rollers? Or can he just simply just sand them out?
Old 11-15-2005, 07:54 AM
roger1's Avatar
I wouldn't use the por product.
In the area past your window gasket, I would use a polyester glazing putty (spread like bondo) over the sanded epoxy and then block sand the glazing to smooth out the surface where those pits are. Then spray a 2K urethane primer over the glazing and do a final blocking.
(Sandpaper wrapped around a paint stirring stick cut to about 3 inches long works well for blocking out small areas like this.) Block your glazing with 120 then 180 grit dry and your urethane primer with 400 wet.
Roll Bar Install Advice Mustangsaly General Rodding Tech 12 12-02-2007 08:33 AM
Welding Books Magnus_Jager General Rodding Tech 6 11-29-2005 03:57 PM
Is this frame damage hopeless? elukas Body - Exterior 20 03-19-2004 04:43 PM
Pitted metal?? Bluepen Body - Exterior 3 08-27-2003 09:36 PM
Review of FatMan IFS Airbag install 1938 Chevy PU Grashopr Suspension - Brakes - Steering 3 08-25-2003 11:16 PM
