Pitted Rust - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-26-2002, 04:22 AM
New Member
Post Pitted Rust
I have a 40 Chevy coupe I recently puchased. The previous owner chemically stripped the car over a years time without cleaning off any of the stripper residue or priming the metal after stripping. Now I have splouches of pitted rust on the car. Is there a recommended chemical that i can use on the rust. I tried muratic acid on a spot and it turned it yellow. I really don't want to sandblast if I don't have to. I have been buffing it with a 80 grit sanding disk but I am afraid the pitting will came back after a time.
Thanks for any help you may be able to give.
Totter
Old 07-26-2002, 02:33 PM
Dave E Shank's Avatar
Post
Contact POR 15 they make products that will seal the metal and prevent further surface rust. Their phone number is 1-800-457-6715. I am sure they have a website if you just dink around you will find it. GOOD LUCK Dave E Shank
Old 07-26-2002, 06:32 PM
Kevin45's Avatar
Just one of the guys
Last journal entry: Vise jaws
Thumbs up
www.por15.com
Kevin
Old 07-26-2002, 11:27 PM
dinger's Avatar
Post
the por stuff looks just like the rust reformer i've used in the past. napa carries their brand, i'm sure many other places will also have their brand name of the same thing. just knock off any scale, dirt, etc, have a clean surface, coat with a brush or rag, let it dry, scuff it smooth with some sand paper being careful not to go too deep as to take the product out of the pitted area. then primer or bondo as needed. it works great, i've used it around window frames on a couple of elcaminos i've painted. good luck, dan
"When I was younger, I could remember anything, whether it had happened or not." - Mark Twain
Old 07-27-2002, 05:48 PM
Don Meyer's Avatar
Post
Ospho is the best product. Its phosphoric acid & kills all the rust.....
Old 07-28-2002, 01:13 AM
Croz's Avatar
Hotrodders.com moderator
Post
Okay, if i have a bare metal car and it has some spots of rust like that, this stuff will remove it and it won't come back? and then can i just go and do my painting?
Old 07-28-2002, 11:48 AM
Post
I had a VERY long and informative article on this typed in and was ZAPPED out of the discussion for some reason or another. I will retype it in word format and post in a little while. I think it might have something to do with the endless pop up adds for gambling, etc
Johnny
[ July 28, 2002: Message edited by: johnny 1986 ]</p>
Old 07-28-2002, 01:21 PM
New Member
Post
Thanks for all the replys guys. I plan on priming this thing with PPG DP90 when I get the rust under control. Is that compatible with the different things you all are suggesting.
Johnny 1986---I,m looking forward to the article you are going to write.
Don Meyer--- this OSPHO that you talk about. Where can you purchase it. I think it might be on the right track. everthing I have read talks about treating the rust and covering it with a phosporous coating.
As I said earlier, I tried Muratic acid on one spot. Now I can buff it back off to bare metal and the next day, it's back to it's yellowish rusty look. I thought I read someplace that you should wipd it down with baking soda and water to neautralize it. Has anyone have any info on this?
I have used the por 15 product on the underside of a 69 Firebird that I am also doing. It is a great product but I don't know if I want to coat the whole exterior of the coupe with it. I'm not sure of the reaction with the DP90 and I think I read somewhere that it has some bad reactions to ultra violet rays If not coated right away.
I have also seen where Eastwood has a product called Oxisolve. It is also suppose to tansform
rust into good metal, onse again I think this is bacause of that phosphate coating that Don Meyer was talking about.
Old 07-28-2002, 02:01 PM
Post
All the above posts are correct. I will add to them as I did before, but got shut out for some reason or another. Here we go.
My first and most important message to relay is to do your project “a panel at a time” The reason for this is you will end up with a much better job and you also will not get tired of it and settle for second place. Always remember SECOND PLACE is the FIRST LOSER. Back to the car. Start by getting some REAL GOOD CHEMICAL RESISTANT GLOVES & SAFETY EYEWEAR of some kind. You sure don’t want to have EYE PROBLEMS when your finished. Next get the roughest Scoth-Brite (red) and either Comet, Bonami or Ajax and scrub with it and water until you end up with a surface that the water does not bead up ANYWHERE. At this time, you can pick out any rust scales that might be present and proceed. The nooks and crannys are the most important if you want all your hard work to show up in the end result. This is referred to as a “waterbreak free” surface in the aircraft industry. This process is used on all aircraft from the small crop duster to the space shuttle. Once you are at this step, grab a new or “soap free” piece of Scotch-Brite and scrub with clean water from the water hose if possible. If not possible, be sure to have A LOT of water jugs on hand. Remember the water break free surface, this is the MOST important step in your project! It insures anything that is on top of it will adhere to it and anything added on top of that will adhere also. Do not let this air dry, I have found that CLEAN shop air is the fastest,easiest and best. Make sure it is CLEAN! By this, I mean, If you blow dry it with an air compressor that does not have a drier or moisture trap on it, you will just be blowing compressor oil on the surface and nothing sticks to oil.
The next steps will be referencing Dupont products as that is what comes to mind. I know I will hear some rebuttals on this, but “chemicals are chemicals” I am aware of some seeming they are watered down and quite possibly so. It is not my intention to endorse one or the other. Once you have arrived at a dry, clean surface, get some phosphoric acid. (some trade names as follows: Ospho, Metal-Conditioner (Dupont), Metal-Prep(PPG). There are a lot of others, just make sure the label states “PHOSPHORIC ACID”. Follow the instructions to the letter on the dilution and while your at it PUT ON THE SAFETY EYEWEAR I have already mentioned. Start scrubbing with the solution following the instructions on the label. Do not let this solution air dry nor dry it with compressed air. Once you are at this step, you can go get some Vari-Prime(Dupont) and spray this on as per the label. Don’t figure “more” is better, it is not. And if you disregard this, you will be real sorry and your billfold will be thinner and also you will have to go buy more Scotch-Brite,etc and start all over again! This is a two part catalyzed primer and is most definitely dangerous to your health. WEAR A RESPIRATOR that is compliant for the chemicals being used. Once you are at this point, you can start doing the required body work as in filling small imperfections, rust pits, bondoing very small dents and so on, at your leisure. ONE panel at a time. Can you imagine trying all this on an entire vehicle? You would either have a bunch of money tied up in a project that is not good or you would have a number 2 job. Always remember: Second Place is the FIRST LOSER. I hope I have not bored anyone with such a long answer to a “seemingly” simple answer. There is a lot more to the Autobody business than a lot of people believe. If there is any typo's it is because I did not want to take the chance and get shut down again. Anyone can reach me at
webzon@worldnet.att.net
Johnny
Old 07-28-2002, 03:55 PM
New Member
Post
Johnny:
Thanks for the info on the rust. I ahve printed it out and am putting it in my file. I do have a couple of questions for you. You state that after you scub it with Phosphric Acid, not to let it air dry or use compressed air. How do you get it dry?
Also is there a reason you recommend Dupont Vari-prime. I was planning on useing PPG Dp90 which is a two part Epoxy primer.
As I said before, I wipe down part of one fender with Muratic acid. Do you know if scubbing it with Comet or Bonami will neutralize it. Right now it keeps turning a rusty yellow.
Thanks
Bill
P.S. There are some nice programs out there on the net that are free to stop the pop ups.
[ July 28, 2002: Message edited by: Totter ]</p>
Old 07-29-2002, 12:27 AM
Croz's Avatar
Post
I havn't been noticing any pop-ups at all... Anyway, i know my chemisty and water will dilute the acid with just a bit, but then will be neutral. Only thing is that water on bare metal makes rust, maybe that is where the baking soda comes in on that one. I am not sure what muratic acid is exactly, but as with any acid, the more water it is in the weaker it gets. At the same time however, if it isn't in any water, it will no longer be an acid and become a compound and maybe the yellow is from the stuff turning into a poweder as you let it set and the water evaporates off. Or the acid just has a residue left behind and a good flushing is in order. Good luck.
Old 07-29-2002, 06:50 AM
New Member
Post
Thanks for the response Croz. I am going to try the method that Johnny posted earlier in this thread. I will let everyone know the results.
Totter
[ July 29, 2002: Message edited by: Totter ]</p>
Old 07-29-2002, 07:09 AM
willys36@aol.com's Avatar
Wiki Edits: 21
Post
Teh reason to use Vari-Prime is that it has an acid additive and is an etching primer; actually eats into the surface slightly and makes a very good base for future coats. That is why you omly need a very light coat. Follow it up with your epoxy and then build/sand primers and you will hve a bullet proof base for your color.
Old 07-30-2002, 01:35 PM
Don Meyer's Avatar
Post
Jonny, PER PAINT SCHOOL:
1. once dn to bare metal,wire brush all the rust off that you can
2. OSPHO(can get from NAPA) the surface
3. wait 48 hrs
4. DA all the the surface
5. prime w/PPG's DP primer
I would recommend that you go to your local PPG supplier & ask them. for all the products they recommend get a spec sheet......Don
Old 08-05-2002, 01:51 PM
Maverick's Avatar
Post
zerorust.com Iam painting my whole truck with this. I have tested it and it works. POR-15 has some bad stuff in it if you inhale it your DEAD. ZeroRust is easy to use thin it and spray it even on rust. Whats left in your sprayer you can pour right back into the can. Good luck!
Rust Spots WildBill Body - Exterior 3 11-09-2007 07:22 AM
need help on wiki article: pitted rust Jon Body - Exterior 4 08-07-2007 10:38 AM
big rust "problem" with former vinyl top car bullheimer Body - Exterior 3 02-14-2006 01:08 PM
Rust Dissolver versus Rust Convertor? 66GMC Body - Exterior 9 11-06-2005 06:48 PM
Pitted Rust chumbucket Body - Exterior 2 11-15-2004 08:26 AM
