Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - pixels are to many!!!
Old 06-04-2003, 07:23 AM
jamnut's Avatar
jamnut jamnut is offline
Rebuilding AGAIN!!!!
Post
Check in your programs & see if you have something that came with your computer like Microsoft Photo Editor, open up the Photo editor, then go to file & open the picture with the Photo editor, then select image, then resize & then change default setting from in to Pixel, then when you type in 640 on the top it should change the bottom to something like 480. Or what ever the maximum pixel size you select. The reason that I used the Microsoft photo editor is because most computers come with that program. You can use the same basic steps with almost any image editing software.
