Place to flow heads Buffalo Area? - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-08-2012, 09:04 AM
zildjian4life218's Avatar
Listen and Learn
Last wiki edit: DIY junkyard electrical fan controller
Last journal entry: SBC 305 Twin Turbo
Wiki Edits: 7
Anyone know where I can have a set of heads flowed and about what it costs in the Western New York, Buffalo, Rochester Area? I am getting ready to port and install a larger set of valves in a set of heads and want to get a baseline of where they are at.
Old 06-08-2012, 10:42 AM
Banned
what heads?
Old 06-08-2012, 12:29 PM
Listen and Learn
Wiki Edits: 7
Mostly sbc heads. Right now a set of 416, then a set of vortecs and eventually a set of gt40 heads for a sbf... who knows what down the road.
Old 06-08-2012, 01:01 PM
Banned
Well, from someone who's btdt, you're better off saving your money for a good set of heads instead of reworking oem castings. You'll always be limited to a small runner and except for the vortecs a crappy chamber and heat crossover. You can dump an easy $250 into putting in larger valves plus 20 hours porting for heads that will be stomped on by $600 chinese recycled soda cans.
I've done too many heads the hard way and while its fun at first after a few sets it becomes a chore.
If you still want to do it you can make your own flow bench that will measure a change in depression. Its not comparable to other benches but it'll do what you're asking.
Old 06-08-2012, 01:20 PM
Listen and Learn
Wiki Edits: 7
Yeah I realize you can only do so much to factory heads and then your still stuck with a factory casting but I really enjoy working on the heads and making them better. Are you talking about the floating differential bench that vizard talked about in his one book?
Old 06-08-2012, 02:20 PM
Banned
Yea I gues so. You just use it to monitor the change in vacuum readings at a given valve lift. You can also caliberate it to get a good approximation of flow with a specialized orfice plate.
Old 06-08-2012, 02:49 PM
Contact your local tech school; they should be able to hook you up with someone. A lot of tech schools send kids out on internships; Im sure the auto systems teacher can point someone out. If you get REAL stuck; Ive always used Port City Machining in Oswego NY. They do a LOT of the Modifieds and Super Mods for the Oswego Speedway
Old 06-08-2012, 02:51 PM
Meh Im an idiot. I just talked to Paul over at Acme Bearings in Buffalo on the phone this AM. He builds the occasional muncie 4spd or toploader. Good guy; funny as hell. 716-885-9000 Tell him Nate from Auto Gear gave you a heads up.
Hes an old timer; he should know someone.
Old 06-09-2012, 03:45 AM
KS doesn't have a bench. You want to go to McQuillens racing engines, Carl has a bench. Or go to Jan-Cen racing or Oddy's Automotive in Buffalo. McQuillens will be closest for you.
http://www.mcquillenengines.com/facilities.html
Old 06-09-2012, 06:39 AM
Listen and Learn
Wiki Edits: 7
Awesome thanks for all the suggestions. Anyone have an idea on what it costs? I wasn't gonna have all the runners done just one intake and exhaust before and after.
Old 06-09-2012, 11:42 AM
I don't remember exactly but it's cheap. You will get a ton of useful information. My friends have home ported heads and when they get them back some of the intakes flow 235cfm and others are at 270cfm, lol. It takes a ton of practice to get them all identical.
66 T Bird in Buffalo, NY Liveaxle Introduce Yourself 1 06-13-2010 03:31 PM
where is the best place two get performance heads for a pontiac 400 resonable 47chevrolet Engine 1 09-05-2007 12:14 PM
Super Flow Heads?? rusty9663 Engine 1 03-20-2006 09:53 PM
Buffalo and his '63 BuffaloRod Introduce Yourself 2 03-06-2006 04:22 PM
Trick Flow heads.....Should I go for them? TheZaZ Engine 22 01-20-2003 06:26 PM
