Place to get line plugs? - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-12-2013, 08:10 AM
Aleksey's Avatar
Founder @ Maintenr
I removed my A/C and looking to buy little plugs that could be found on new parts that cover up the holes from dirt.
Any suggestions?
Old 04-12-2013, 10:34 AM
sedanbob's Avatar
A local A/C shop should have hundreds - would probably give them to you - especially if they thought you would be bringing your car in later to have the system evacuated and charged.
Or just wrap them with tape.
Old 04-12-2013, 12:06 PM
One option is to put several layers of plastic (plastic bag or plastic wrap) over the fitting, and then wrap duct tape around it tightly. Put the tape only on the plastic and the hose, but not on the hose fitting, so you won't have adhesive to clean off the fitting later. It may not be a truly airtight seal, but it will keep the dirt out for now.
Bruce
Old 04-12-2013, 01:31 PM
Aleksey's Avatar
Founder @ Maintenr
Where do they get them ? I'm aware of the tape but I have an OCD that will not slide.
Old 04-12-2013, 02:11 PM
Banned
go to a napa and go to the rack that has the HELP parts on it or Autozone has them also you will need hose clamps also . It is a kit of different sizes .
Old 04-12-2013, 03:00 PM
sedanbob's Avatar
The A/C shop gets them off the new hoses they install.
Steering leak where rubber line meets metal line bigdog7373 Suspension - Brakes - Steering 2 06-24-2011 07:26 PM
Best fine-line tape and tips to make a perfect line. smithkustoms Body - Exterior 9 03-24-2010 11:29 AM
3/8" female to male flex line needed. Any cars front wheel cylinder frame line? Ripped Suspension - Brakes - Steering 2 03-12-2008 02:47 PM
FUEL LINE & TRANS LINE SIZE/TYPE leejoy Hotrodding Basics 7 11-29-2005 10:59 PM
TH-350's Line presshure all over the place Old School Nut Transmission - Rearend 5 07-20-2004 10:27 PM
