Place for suspesion bushings - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-03-2008, 11:20 PM
Where is a good place to get rubber bushings perferably adjustable. If I cant find any I guess I'll have to go with polyurathane its for a set of ladder bars. Thanks scott
Old 04-04-2008, 11:08 AM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
I may be old and dumb but i do not believe i have ever heard of an "adjustable bushing" do you mean rod ends?? that is what we use on those..If so all the usual online culprits have them..
Sam
Old 04-04-2008, 09:14 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
I'm not sure I'd want rubber bushings in ladder bar ends, Im sure they're sleeved but they take a lot of abuse, on the other hand, I've never run ladder bars. IMHO, go with the poly if that's what you're referring to. In my 4-link car, I'd beat out rubber bushings very quickly!
Semper Fi
Old 04-05-2008, 10:27 AM
Rod Ends
Rod ends Is what I meen. Heim joint are a ruff ride. Polyurethane are better only one ive seen are from art morrison and the front 2 is what im considered about need some thing stong might run heim joints up front. Scott
Old 04-05-2008, 02:47 PM
gOT it
cURRIE JONNY JOINT 40 BUCKS A PEICE BUT ARE GREASABLE WITCH i DONT SEE MUCH STONG IS WHAT IM GOING FOR.
Old 04-05-2008, 06:19 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
You don't think they'd be stong enuf, the ones witch you mention?
Semper Fi
Old 04-06-2008, 08:45 PM
Bushins
The rod ends from art morrison stainless steel ones I think PG 63 in their catalog. Considering there is only one point on the front holding the ladder bars stronger is better. And I have heard regular heim joints are a bit rough riding. I'll probably run the Stainless steel ones out back and the Currie ones up front. Sound good Also curries johnny joint come with a greese fitting wich i dont see on the other ones.
Old 06-20-2008, 06:24 AM
The Currie Johhny Joint is a fantastic piece! I had all poly and converted to half poly half Johnny Joints. My car has a 462 with globbs of torque and these joints keep everything in a manageable straight line.
Name:	Johnny Joints install 002.JPG
Old 06-22-2008, 11:27 AM
Yea I need some thing taht i know is going to be stronq on the front. After all its going to be a ladder bar set up. Scott
Old 06-01-2009, 11:40 PM
finally getting back to it
Im getting back on the truck. Ladder bars will Ill get what I need when i get there Currie up front and poly on the axle end or maybe poly on the front to its gonna get driven so the smother the ride the better
Mustang II control arm bushings 47chevy Suspension - Brakes - Steering 2 11-26-2007 04:30 PM
Linkage Bushings Nova Doug Transmission - Rearend 1 07-05-2007 07:23 PM
rad support bushings price Body - Exterior 0 05-02-2007 11:08 PM
Welding a panel in place Quarter Flash Body - Exterior 6 03-22-2007 02:56 AM
Redoing 74 Nova Bushings - Initial Planning topdogger Suspension - Brakes - Steering 8 11-13-2006 10:28 AM
