Placing a return gas line - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-18-2012, 09:59 AM
Where is the best place in a new gas tank to put the return line ?
I have seen that it should go in the top , I have also seen people say it should go in the bottom.
Mine is in the bottom at the back of the tank, right beside the outlet. Will that cause a problem ??
Old 07-18-2012, 08:27 PM
35WINDOW's Avatar
Last journal entry: Update on my Build-Lights
You know, if you look at a lot of the Factory stuff they will put it right back in at the Fuel Pump-I'm certain that is fine, but I will tell you my opinion as I am going through this same issue-
You haven't told us your combo (engine size, hp rating, fuel line sizes , Pump flow, etc.), so, I will tell you my story, and maybe it will help-
I am upgrading my system from a -6 (3/8") line to a -8 (1/2") line because of my combo (high horsepower big block with fuel injection requiring a return line)-I didn't have a return line before (I was going to run a Carb)-
My new return was designed (Rock Valley) to point straight down, right at the pickup tube-after looking at it (It sits in a well), I changed it so that it flows out at 90 degrees)-why? The Pump flows 130gph and I could see major amounts of sloshing/frothing/agitation at idle or low speeds with that idea-Pump cavatation is a bad thing-
If I had the chance on a new Tank (like you), I would put the return on top with a tube or diffuser pointed away from the pickup in the Tank, or, put the return as far away from the pickup as possible with a well for the Pickup (or Pump) to sit it to control the agitation-this is only my opinion, but I hope it helps-
Old 07-19-2012, 08:28 AM
Sorry about leaving that stuff out.
The car is a Triumph Spitfire.
Engine Chevy 4.3 L, around 200 HP, 3/8 fuel line, pump flow 180 L/h.
The way mine is set up now the return is on the bottom right beside the outlet. Will the fuel in the tank (around 10 gal.) cause enough pressure to force fuel into the return line stopping the fuel from returning??
Old 07-20-2012, 08:11 AM
1971BB427's Avatar
I would always put it in the top myself, but I doubt it would make a difference in how it functions.
fuel, gas tank
Holley fuel pump, return line or not to return line??? JD's camaro Engine 1 07-16-2010 05:17 PM
Return Fuel Line Seon Engine 5 05-26-2007 09:14 AM
what to do with gas return line? dan 2 Engine 7 12-23-2006 12:58 PM
what to do with gas return line? dan 2 Engine 1 12-22-2006 11:55 AM
What to do with return line? CorvetteSteve Engine 5 04-07-2003 08:37 AM
