Planning ahead-67 Mustang Hood/inner fender paint - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-28-2013, 01:35 PM
Mach1460's Avatar
Last journal entry: Project 92' Eddie
I'm working on my brothers 67 Mustang coupe. Currently im fixing some rust spots in the engine compartment and going to start stripping all the paint to start fresh. I have a few questions on "when" to do these things..
We ordered a new hood with the built in turn signals and were also going with candy apple red for a color and should I paint the underside of the hood while its off? When the hood is open (car finished) I want the paint on the underside to match the rest of the car (not be darker or lighter) or would this not be noticeable?
Behind the front fender area where the door hinges attach to the body I would like to paint that as well before the fenders go back on.. (see pic) but want that to match too. Am I over analyzing this? Opinions? Thanks
Old 08-28-2013, 01:57 PM
Faith - Respect - Trust
This all depends on what you call candy apple red...If it's the candy apple red that is available in a single stage or base coat paint and not the candy apple red that's a tri coat, then there shouldn't be any trouble matching the the door jambs or the underneath of the hood if you paint either before the rest of the car. If it is a true tri coat candy color, there could be an issue, however, if you paint the pieces that you want to paint separately with the same number of coats and the same gun set up, again, there shouldn't be an issue.
I'm fairly confident that the color your talking about is not a tri coat...so if that is the case, I wouldn't worry in the least, just make sure that your substrate ground coat is the samd color in the jambs and the underneath of the car...that way the same number of coats of color will look the same on the outside of the car as the hidden pieces.
Hope this helps
Ray
Old 08-28-2013, 02:00 PM
Mach1460's Avatar
It will be a base/clear- I have not yet ordered the paint so I am not familiar with the "tri-coat" you speak of. Ill research that. Thanks
Old 08-28-2013, 02:15 PM
Ford had a Red in those years called candy apple red...I'm confident that is what your talking about, but I wanted to cover all the bases...a candy color in the painting world is a ground or base coat color with a transparent color sprayed over top and then cleared.
Hope this explains
Ray
Old 08-28-2013, 02:20 PM
Mach1460's Avatar
Yes, the original Ford color. I was not sure if it was a "candy style" (transparent) paint or just the name of Ford's red. Thanks for clarifying
Old 08-28-2013, 02:23 PM
That being the case, painting the underneath of the hood off the car is a good idea, the jambs can also be painted prior to the car being painted.
Ray
Idea thread: Planning my semi-permanent paint booth, hoping for your input Lizer Body - Exterior 48 09-08-2013 09:09 PM
Fender/Hood Alignment on 65 Impala fosterdl Body - Exterior 16 06-11-2012 07:13 PM
Planning a paint job. Coaner Body - Exterior 2 04-07-2011 09:48 PM
67 Mustang Fender Emblems. 67Mustang Al. Body - Exterior 4 08-29-2009 08:54 PM
Fender and Hood Alignment Issues Fe3O2 Body - Exterior 8 11-21-2008 06:51 AM
