Originally Posted by 39chevy
I have a Hypertherm Power Max 30, and I heard there is a tip I can buy that snaps on this so I can drag my torch right on the material to be cut so I keep it the exact distance away. Does anyone know where I can purchase this? Thanks, Dana
ummm...
The Power Max 30, like most of the Hypertherm plasma cutters I have seen, were designed for drag cutting i.e. you place the tip at 90 degrees flat on the piece being cut and drag along your cut line.
The guide tool referenced in the prior post was designed for Miller machines which do not come with drag tips.
Check out the Powermax 39 setup video at the bottom of this page. You can get the optional Hyperthem snap on cap at your LWS.
http://www.hypertherm.com/en/Trainin...x.jsp#powermax
