-   Garage - Tools (http://www.hotrodders.com/forum/garage-tools/)
-   -   Plasma cutter question? (http://www.hotrodders.com/forum/plasma-cutter-question-176472.html)
39chevy 04-18-2010 01:46 PM
I have a Hypertherm Power Max 30, and I heard there is a tip I can buy that snaps on this so I can drag my torch right on the material to be cut so I keep it the exact distance away. Does anyone know where I can purchase this? Thanks, Dana
evolvo 04-18-2010 02:24 PM
Google is your friend :mwink:
http://www.drillspot.com/products/60...ller_guide?s=1
39chevy 04-18-2010 07:14 PM
Evolvo, thanks alot yes this is exaclly what I was looking for! Sweet!
Conrad_AZ 04-19-2010 04:02 PM
ummm...
The Power Max 30, like most of the Hypertherm plasma cutters I have seen, were designed for drag cutting i.e. you place the tip at 90 degrees flat on the piece being cut and drag along your cut line.
The guide tool referenced in the prior post was designed for Miller machines which do not come with drag tips.
Check out the Powermax 39 setup video at the bottom of this page. You can get the optional Hyperthem snap on cap at your LWS.
http://www.hypertherm.com/en/Trainin...x.jsp#powermax
39chevy 04-19-2010 05:34 PM
Thanks, but what is LWS? Also where can I see a pic of the snap on cap? Thanks, Dana, (as u can see) I am a beginner w/ this tool!
matt167 04-19-2010 06:35 PM
Local welding shop... sorry I cannot help you with finding a cap
