Plasma cutter question? - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-18-2010, 12:46 PM
I have a Hypertherm Power Max 30, and I heard there is a tip I can buy that snaps on this so I can drag my torch right on the material to be cut so I keep it the exact distance away. Does anyone know where I can purchase this? Thanks, Dana
Old 04-18-2010, 01:24 PM
evolvo's Avatar
Google is your friend
http://www.drillspot.com/products/60...ller_guide?s=1
Old 04-18-2010, 06:14 PM
Evolvo, thanks alot yes this is exaclly what I was looking for! Sweet!
Old 04-19-2010, 03:02 PM
Conrad_AZ's Avatar
Ya Gotta Drive Them!
Last journal entry: Moved...
ummm...
The Power Max 30, like most of the Hypertherm plasma cutters I have seen, were designed for drag cutting i.e. you place the tip at 90 degrees flat on the piece being cut and drag along your cut line.
The guide tool referenced in the prior post was designed for Miller machines which do not come with drag tips.
Check out the Powermax 39 setup video at the bottom of this page. You can get the optional Hyperthem snap on cap at your LWS.
http://www.hypertherm.com/en/Trainin...x.jsp#powermax
Old 04-19-2010, 04:34 PM
Thanks, but what is LWS? Also where can I see a pic of the snap on cap? Thanks, Dana, (as u can see) I am a beginner w/ this tool!
Old 04-19-2010, 05:35 PM
Wiki Edits: 31
Local welding shop... sorry I cannot help you with finding a cap
plasma cutter Holder350 Garage - Tools 13 10-30-2007 09:07 AM
Which Plasma Cutter should i buy??? bg Garage - Tools 2 02-08-2004 04:12 PM
plasma cutter died tm454 General Rodding Tech 6 11-28-2003 03:14 AM
