plasma cutters - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-28-2006, 08:47 PM
plasma cutters
I am thinking about getting a plasma cutter but don't realy know what to get, I would be cutting 1/4" or less steel and sheet metal. I have Know ideal what brand or what amp to get. Lets here your thoughts on it. Thanks Dave
Old 09-28-2006, 11:38 PM
powerrodsmike's Avatar
Wiki Edits: 161
I have a thermal arc XL38 that I bought 9 years ago. It is light, easy to use , parts are available , it has held up real well being used at its capacity for many hours. I like the tips and torch on that machine because they are straight sided, and you can drag them around a plywood or poster board template and get a cut that is pretty accurate.
( I had a job one time that the cutouts we made with the plasma torch had to be + or - .030". We could hold them to .020" cutting by hand with a steel template)
It's capacity is .375. They are usually rated by thickness cut.
I have heard that ESAB makes a really good machine also.
On mine,you have to change tips every 15' or so on 1/8" if you want to keep a nice edge. After that the plasma stream starts to get erratic and the cut suffers. A tip change is about $10.00 but worth it because you save a bunch on grinding discs and time.
I would call a plasma torch a very good investment.
Later, mikey
BE different....ACT normal.
Old 09-29-2006, 08:35 AM
1931 steve's Avatar
Last wiki edit: How to rebuild an engine Last photo:
Wiki Edits: 4
I have a Matco Tools PC120INV plasma cutter, Works like a dream. Definitely well worth the money. This thing will take a 1/4" stock and cut it like hot butter, same thing as Mikey said replace the tips and the cut stays very nice.
Steve
Plasma Cutters HEDGE Garage - Tools 7 01-21-2006 06:59 PM
Info for plasma cutters zonk Garage - Tools 1 01-28-2004 10:44 AM
welders and plasma cutters casper455 General Rodding Tech 7 12-18-2003 10:58 PM
