?????plastic adhesion promoter - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-12-2009, 01:26 AM
i primed my motorcycle yesterday.....some of primer covered old scuffed paint but other parts were bare plastic......a friend of mine told me that the primer would lift after a period of time because i did not use plastic adhesion promoter......do i need to sand all that primer back off and apply this.
i did scuff all the bare plastic with 400
Old 10-12-2009, 06:37 AM
Old Fool's Avatar
the best option would have been to prime with epoxy.
Old 10-12-2009, 07:30 AM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
Rule of thumb is if it is a "floater use promotor" place the part in a bucket of water and if it floats then use a promotor..there are several different plastics that may have been used so one needs to identify just what it is youhave there.....
Sam
Old 10-12-2009, 01:08 PM
.im really looking for the correct answer to my question...while all the information in these two posts is useful in the future...... i cannot use it now.....i dont have a tank big enough to put a side fairing into.....but i need to know if the primer i used will stick to that abs plastic
What is an advantage of priming with epoxy
Old 10-12-2009, 01:19 PM
88_mopar's Avatar
Any bare(unprimed) bumper covers or plastic trim we get at work get soaked with pla-stik before paint. How big is the area and does it see any flex or abuse?
Old 10-12-2009, 06:39 PM
these are all sport bike fairings....abs plastic...doesnt flex much.
ive been told to sand it off by many people now.....so i will do that and may switch to epoxy.....i thought epoxy was used only for the first coat of metal and sometimes for sealer when mixed right
Old 10-12-2009, 08:44 PM
Old Fool's Avatar
Epoxy will grip the plastic better than any other method out there, bar none.
Call Barry at SPI ( 760-781-2220 )and get the 411 on epoxy.
Does bulldog adhesion promoter need a primer? SplitFire Body - Exterior 9 08-09-2014 11:49 AM
Exposed Adhesion Promoter jcclark Body - Exterior 7 06-08-2009 02:51 PM
Adhesion promoter oldred Body - Exterior 4 10-13-2007 08:23 PM
Bulldog adhesion promoter. jcclark Body - Exterior 8 08-25-2005 07:29 PM
dupont waterborne adhesion promoter 327amc Body - Exterior 0 01-04-2004 06:18 PM
