Plastic bumper disaster - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 10-29-2009, 06:29 AM
deadbodyman's Avatar
Wiki Edits: 11
light coats,not heavy ones,it always turns white when its to heavy,keep tryin ,you'll get it...
  #17 (permalink)
Old 08-02-2013, 09:08 AM
Are there any good aftermarket paints/coatings that will protect the urethane bumpers during accidents? The darn things get damaged so easily, and repairs are costly. Any new coatings/methods out on the market that really work?
  #18 (permalink)
Old 08-02-2013, 11:02 AM
astroracer's Avatar
Old thread, back from the dead... Start a new thread in the Paint/Body section.
To answer your question... the best prevention is to stay out of accidents...
  #19 (permalink)
Old 08-02-2013, 02:01 PM
Thought I was doing the right thing by doing a search, finding a similar topic, and posting to it, instead of flooding the site with duplicate threads.
Don't get in an accident....fantastic advice.
  #20 (permalink)
Old 08-02-2013, 02:52 PM
Faith - Respect - Trust
"jtomasik". I respect the fact that you took it upon yourself to do a search, that's exactly what the "search" feature is for. I've read the entire thread and some of the advice was less than stellar. Mike "Deadbodyman" is correct about the method for applying adhesion promoter...however, if I read your post correctly, your asking if there is anything out there today that will give you better adhesion on plastic or rubber bumpers than what you have on it now in the event of getting rock chips or minor scuffs.
If that's your question, the answer is yes. This thread was started in 2009 and the reason I mentioned that the advice was less than stellar is because products where available then as well that would outperform some of the finishes that exist today. The person who started the thread was using aerosol spray cans to paint/repair his bumper. Other than adhesion promoter and even adhesion promoter, when applied with a spray gun goes on much more easily, is atomized better to give more even coats and well, in my opinion, aerosols for the most part, should be used for spraying model car.
What can be done on these types of bumpers is to clean the surface with a quality Wax and Grease remover, repair any chips or scuffs with sandpaper, I would use a 320 grit paper, feathering the effected area back so that the chip or scuff seems to be non existent when you feel it. If your down to the raw plastic, adhesion promoter should be applied, two medium wet coats and allow them to flash, flash means that it is not wet anymore to the touch. Depending on brand, read the instructions, you can now apply a quality Epoxy primer. I prefer SPI Epoxy for several reasons, it lays down nice and smooth, has respectable build and incredible sanding qualities for an Epoxy. Now, an Epoxy primer is exactly what it sound like, it's basically a glue that acts like a primer and remains flexible (very important on rubber or plastic parts...in case you get into that little mishap). I would recommend 2 coats of Epoxy, let it cure, usually 24 to 48 hours and sand the Epoxy with either 400 dry or 600 wet paper. The Epoxy primer will act as cushion between your plastic/rubber and your top coat/paint. Clean the surface with a quality Wax and Grease remover, make sure that it has completely dried and apply your base coat and clear. When your applying your clear coat, you could add "flex agent" to your clear so that if the bumper, if disturbed, the clear won't crack as easily.
By doing it this way, you will have a better, more flexible paint on the surface of your bumper. If you use rattle cans, for the most part, you will not get the results it sounds like your looking for.
I hope this helps and, just so you know, you did the right thing by doing a search before posting...if you would have wanted to start a new thread, that would have been Okay as well. If you need any more information, please feel free to ask.
Ray
  #21 (permalink)
Old 08-04-2013, 10:27 AM
Wiki Edits: 11
deleted.....
Painting plastic bumper davidd_45 Body - Exterior 7 08-12-2009 07:42 PM
Plastic bumper covers bluechevyz28 Body - Exterior 1 07-20-2009 07:41 PM
Plastic Bumper Question MyOtherCarIsAnApache Body - Exterior 4 01-20-2009 03:25 PM
Plastic bumper refinishing MAUSS Body - Exterior 1 05-05-2008 12:08 PM
Painting plastic produces a different color, myth? MARTINSR Body - Exterior 15 03-21-2008 11:14 AM
