All bare plastic should have adhesion promoter first.
You can paint right over that but it's better to prime it. if you want durability against rock chips and scratches, a couple coats of epoxy primer makes a world of difference. I use to use 2K (urethane) primer on all the bumpers I did and it worked great, but since I switched to epoxy I can tell a big difference on them not getting pitted as much from the road. If you have cracks, you need to strip or sand at least down to below the cracks. I've used strippers without any problem, if you have a large portion that needs redone then stripper may be the way to go. Some fear it attacking the plastic, I haven't had that happen, depends on the stripper, so test a spot on the backside first to be sure. You'll get a better job the more you can remove. You want min. film build on bumpers. I don't use flex agent and have noticed my older bumpers stayed flexible long after I've painted them. I guess which clear you use would make a difference.
| Painting plastic produces a different color, myth? | MARTINSR | Body - Exterior | 15 | 03-21-2008 10:14 AM |
| Plastic bumper cover | Polish Painter | Body - Exterior | 5 | 02-28-2008 09:02 PM |
| Plastic Bumper help?? | DV8 | Body - Exterior | 5 | 12-17-2006 10:28 AM |
| Refinishing plastic, kinda.... | WakBordr7387 | Interior | 2 | 05-16-2006 03:05 PM |
| plastic bumper repair | mark2002 | Body - Exterior | 2 | 12-30-2003 06:35 PM |
