plastic fuel line ? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-10-2013, 06:38 PM
plastic fuel line ?
What are you guys using for fuel line on a TBI. I was hoping to run all plastic fuel line. I was wondering if there was a kit or anything out there to convert old hose clamp style ends on my fuel tank and the GM threaded lines on the back of the TBI to plastic clip on lines?
Old 03-10-2013, 07:13 PM
LATECH's Avatar
You can get these . They are compression fitting on one end and hose barb on the other. The plastic line will shove on the barb (takes some grunt) . I use them on EFI all the time.
As long as you have the short metal lines for the Throttle body, you can put them on the line after cutting the one end off.
I have used these and other styles of hose barbs on EFI systems along with the nylon line. It works very well.
Be ure to route your lines safely away from exhaust heat and moving parts.
ID:	72196   Click image for larger version
Fact is stranger than Fiction
The Following User Says Thank You to LATECH For This Useful Post:
53 Chevy (03-10-2013)
Old 03-10-2013, 07:29 PM
thats perfect, I was looking at $200 kits and I thought there had to be a better way.I would think that My local parts store would have ends for the fuel filter. Thanks
Old 03-12-2013, 11:05 PM
1Gary's Avatar
Last journal entry: 383 dyno sym
It sure does take some grunt to get them into the plastic lines.There is a tool that makes alittle easier,buy not by much.What I hate about the plastic line fuel system is the crimp hose clamps.I don't trust them and doubled them up on every splice.
Old 03-13-2013, 07:45 AM
LATECH's Avatar
Gary1 those crimp style clamps are called Oetecher clamps after the designer of course....
The line itself...what i have done in the past that works fairly well is to use an anvil from the double flare kit, you know the 2 piece bar looking thing that hold the metal tube, and I clamp the plastic in that, keeping short, putting the fitting in a vise, giving a good handle for the plastic that allows me to grunt that baby on there. Sometimes I heat the metal barb fitting a tad (not too much) to help soften the tubing as it slides on.
LINE X on plastic trim Cape Cod Bob Body - Exterior 1 08-03-2012 09:31 AM
Fuel line kit for Holley 4150 and stock fuel pump colin911 Engine 4 09-13-2011 08:24 PM
Use of Plastic or Brass Fittings in Fuel Line? JohnTN General Rodding Tech 8 11-02-2007 09:57 AM
Copper Brake Line,Fuel Line redlightning General Rodding Tech 6 08-23-2006 08:50 PM
FUEL LINE & TRANS LINE SIZE/TYPE leejoy Hotrodding Basics 7 11-29-2005 10:59 PM
