plastigage - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-22-2010, 02:21 PM
plastigage
DO i have to use plastigage or mic the bearings on the crank if im using a new crank and new pistons and rods? Also what do they mean when they say check your crank for play when you put in new pistons and rods? AS you can tell this is my first build....thanks joe.........also does the damper on the 350 sbc have different timing marks for different years...i have a 80-85 and the tdc is at 12 oclock and i cant read the timimg pointer which is at 1 or 2 oclock...can i just buy a newer damper or do i need the old timing cover? again thanks ....joe
Old 06-22-2010, 02:48 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Yes- you or your machinist has to verify that the oil clearances w/the bearings that you plan to use are within spec, and that the machining done was done right, i.e. no taper, out of round, etc..
End play (aka "end float") is measured w/the crank in place and the thrust bearing seated by driving the crank fully to one end, then fully back to the opposite end, then measuring the top and bottom thrust surfaces. I'm sure there are tutorials on this on the 'net.
It is best measured for total as well as each half of the thrust bearing to be sure the load is "shared" by the two bearing halves.
Then there is the rod side clearance that has to be checked to be sure the rods are close enough to each other on each crank journal, but not too close.
The three most common locations for the timing mark on the damper:
The pre-'69 damper has the TDC mark 2 before the keyway in the ID of the damper.
The damper used from '69 to mid-80's is 10 before the keyway. You'll find that aftermarket dampers are the 10 type, as are the tabs sold in the aftermarket unless they're adjustable.
The third timing mark used from about 1986 to about 1991-'92 is 40 before the keyway. IIRC, this damper uses the timing cover tab @ 12 o'clock.
If you're unsure, or just want to check the accuracy of the tab/mark for TDC, DETERMINE TDC and MAKE A TIMING TAPE will help you to see for yourself.
Old 06-22-2010, 06:09 PM
plastigage
Thank you for your help...
Question about Plastigage and bearing clearances v8hed Engine 2 01-23-2010 10:23 AM
Engine Building Help...Connecting Rod Caps. V8 Super Beetle Engine 15 07-08-2009 01:11 PM
383 Plastigage mightycarlo10 Engine 11 02-10-2008 08:59 AM
Plastigauge Con Rod Clearance?? sexypizzaman Engine 9 09-17-2007 05:53 PM
Plastigage Litdave Engine 9 06-02-2004 02:02 AM
