platinum plug in hp engine - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-06-2006, 05:30 PM
runn141's Avatar
SB S10
would platinum spark plugs in 10:1 compression engine work well? or would they act like a glow plug and detonate? im curiuos about ACDelco
Old 09-06-2006, 05:55 PM
Jmark's Avatar
I run Delco double plats in all my vehicles. My personal truck has 9.4 compression and does fine.
Old 09-06-2006, 06:03 PM
runn141's Avatar
SB S10
do you run the colder plug?
Old 09-06-2006, 07:28 PM
302 Z28's Avatar
My Fastburn 350 crate came with AC Delco platinum plugs.
Vince
Old 09-06-2006, 07:38 PM
cabowabo's Avatar
big Q
msd box 6 al being used
if you use mds6 al box then i would just use copper plugs since theres a good hot spark should be ok plus its cheaper
Old 09-06-2006, 07:59 PM
weirdbeard's Avatar
1976 Ranchero GT
Last journal entry: Almost time for the first drive!
I put platinum plugs in my uncles mustang GT and within a month they came apart in the engine and made a big bad mess! He picked out the plugs. NOT ME! The dealer said NEVER use platinum plug in a 4.6 ford! I will never use them again in anything.
Old 09-07-2006, 10:43 AM
If you don't mind changing plugs once in a while, go with a standard plug. The platinum plugs are actually less conductive, but won't wear out as fast. The best of both worlds are iridium plugs, which are both conductive and long lasting, but more $$$.
Old 09-07-2006, 12:02 PM
Jmark's Avatar
No, just found the correct number by application and got those. I actually bought a full CASE of them off ebay. Watched for a while and saw them come up. Paid about $1.12 each for the double plats. Got plugs for the rest of my life!! Just like the cases of big rebate oil from Checker and cases of oil filters I got cheap too. Always looking for a deal. Anyone need any 2 cycle boat oil???? I got about 150 bottles of Penzz outboard mix oil too! LOL
Mark
Old 09-07-2006, 01:12 PM
Technical Support Barry Grant
The only advanatage to a platinum plug is that they will last longer, but they will not perform better then a fresh traditional plug. 99% of all Race cars use a traditional style plug, not platinum.
Which radiator for 330 HP crate engine HotRodMan Engine 1 09-02-2006 01:46 AM
Total Newbie Question emerald.mirror Engine 17 02-06-2006 12:29 AM
how nuch HP my engine will have? bigpapagun Hotrodding Basics 7 01-15-2005 08:43 PM
Pontiac engine spark plug info D.Cantrelle Engine 0 06-01-2004 07:36 AM
Cam Help black66 Engine 3 05-12-2003 07:15 PM
