Unless this is some special/rare car, the vinyl top would have to go. Can't beat the price: free! the buddy with the shop can make it look pretty later, along with the parking lot dings. Since the small block appears to be in good shape, an inexpensive tune up would most definitely be in order. As for a "big ticket" item, I would first and foremost have a complete stem to stern brake system inspection/service completed. Adding the go-fast goodies is always a blast, but stopping fast can be a lifesaver! In driver's education we were taught not to overdrive the beam of the headlight. I would like to add to that not to over drive the capability of the brake system. Been there, done that, can't say I liked it too much!
Gotta agree wit 345
LOL I gotta agree with 345 coupe that the last thing you wanna find out about your new 30 year old build up that runs (somewhat) is that a brake hose or wheel cylinder is gonna teach you all about off roading or telephone pole grille mods! Pull all the wheels and start with a brake job. heck you can budget 30 bucks a week the tou should be able to at least rebuild one wheel per weekend! ps I can always recommend that a saturday budweiser package will usually get at least a free assistant or two!. ps just like 345 I also outdrove my brakes on my first toy, heck I had to work each weekend at a pals body shop for the whole summer just to it back together, good luck on this project sounds like a winner. ps a lotta wd 40 will help all that 30 year old bolts to come off easier! enjoy!!!1
true story guys
My son found grand-maws Buick parked under a cover in some guys driveway. Ran, kinka bad but didn't smoke. Would not move, the brakes were froze up. Guy had to have $1200 but Jason told him like it was and he had $600 cash and would get it out of the driveway TODAY!! Flat bedded it home. Beat the wheels off the beat the drum off then cleaned up the drums and the thing had new brake hard wear and shoes. Put gas in it, tuneup including wires , cap n rotor and it runs like a champ.. Suggested to Jason he install a duel reservoir master cylinder from a later Buick but first he said he just wanted to drive it around the block.. He puts it in gear, the throttle stuck, he steps on the brakes and broke a line, his dream car is now headed for the fence after throwing gravel all over me and his mom, right into the chain link fence that stopped it without a scratch on the car.. Point in fact the brake lines ALL needed changed and the new duel master cylinder was installed, no more brake problems. Jason found this Black 64 Buick special in a condo near one of his friends home and talked to the owners wife about how long it had been sitting in her driveway and when did her husban get home from work to talk a deal. Put Cragers and new rubber and buffed out the Purple/Black paint. They are out there you just have to look.
Todd Rat Rods Rule! |
Assuming the brakes were good (I just went through a similar experience) I'd take that $340 and hit up a swap meet. A used intake, carb, and headers are in order to wake the beast up. No ignition would be needed, the stock HEI unit, wires, and plugs would be just fine. The first $60 would go towards the gaskets and other little things like the plugs and wires I am gunna need initially. After that it's time to save up and within a month or so I could afford a cheap exhaust system. And I haven't even touched the loan money yet
Play the,"Where to start?" Challenge
I'd like to buy a vowel???......Wait no!! I'll take"Duration specs of various cams"for $600..Alex.......
![]() If it were me and I had a mid 70's car to rod(78 monte see the similairity??)If it had a good running 350 I'd break the $340 into headers and a mild cam and if enough was left over a used E-bay duel plane 4bbl intake.If it had a 305 I'd find a $350 350 I could hear run.Then save my $30 a week for headers,a cheap cam and used 4bbl intake off ebay.And off course a cheap set of guages to monitor our precious first hotrod engine. Then once the motor was taken care of.I would save my $30 a week for a rear gear set and a used posi unit or have good ole dad weld the spider gears. Then would be better stuff such as getting a holley carb,a Sunn super tach,used mags and better tires. |
I would take the beginner loan which would bring the initial budget up to $1340.Since this is my only vehicle,I would refrain from any mods that would keep it off the road for too long.This is assuming that I want it to go fast and looks aren't as important.
My first purchase would be a repair manual.{(-16) budget=1344} Next,all the components necessary to refurbish the brakes myself.{(-150) budget=1194} Factory wheels are not wide enough.Can get a set of Steel Rally type wheels at salvage yard and clean them up.{(-40) budget=1154} Need new wide tires.{(-300) budget=854} Change the fluid and filter in the tranny.Install new modulator.{(-40) budget=814} New U-joints.{(-20) budget=794} Complete tune up on engine with oil change.Flush radiator.Install new fuel pump and water pump.New belts and hoses.{(-140) budget=654} Budget high torque cam and lifter set utilizing factory lift.New timing gears and chain.Gaskets necessary to install cam.{(-120) budget=534} Used performance intake and Holley carb with rebuild kit.{(-160) budget= 374} New battery including cables.{(-50) budget=324) Purchase and install a set of economy headers and a prefab duel exhaust system with mufflers.{(-320) budget=$4} Get a value meal at Taco-Bell.{Budget=0} Not gonna worry about looks right now.Spend the weekends doing minor body work.Use weekly budget to pay off loan early. When loan is paid off,another can be taken to budget the paint and interior. Be happy with what I got until I can afford to build my dream. This is all assuming that the suspension on the car is in good condition.The car I used is a 1974 Chevy Malibu with a 350.Prices are based on what it would cost me in my area.
DR. Lindz, you got it going on!
Moby302. The make really doesn't matter. This could be anything froma 72 Luv truck, 75 Aspen, 78 Monte, 0r 74 Ford 3/4 ton. I didn't think about going for the loan right away. I also noticed that no one did what I did when I got my first car. STEREO! My entire point in doing this scenario is to see what some would do first. I hope the new folks to hot rodding get some ideas of what is important. Chrome won't get ya home! |
Basically, if it's a nice unit that someone else might like to have, I would take the $340 to make the repairs it needed to be safe, spit shine it and sell it to the highest bidder. Take the loan plus the money I made off the car and look for something I had been lusting for. That is just what I would do! I have always been a horse trader!!!!
I love the smell of a quick deal! If the car was cool enough to keep I would add the usual cam, intake, carb, headers, wheels and tires after making it safe for the road. |
