PLEASE answer quick - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-20-2004, 09:54 PM
chevelle_502's Avatar
Get out the ducktape...
Last journal entry: Front brakes
Wiki Edits: 5
PLEASE answer quick
Have a 1987 chevrolet suburban 4wd. The ignition locked up and rocking the steering wheel does not work. Any info would be helpful.
Old 07-21-2004, 05:05 AM
302 Z28's Avatar
More than likely the ignition tumbler has failed. Once this happens it is virtually impossible to get it working without help from an auto locksmith. What happens is the tumblers (lock pins) are held in the pot metal tumbler by several crimps. Once these crimps give way, one or more of the lock pins pops up which prevents you from rotating the tumbler. It is a very easy repair, but you have to know what you are doing. I would call a competent auto locksmith.
Vince
Old 07-21-2004, 01:41 PM
horvath's Avatar
Acoustic Rock ... for real.
Last journal entry: About Fusible Links
Your local mechanic may be much less costly -- I wanted to replace the key-ignition in my column ... a locksmith wanted over $100; my local mechanic put a new one in for $15.
Alan
54 Chevy Pickup
Old 07-21-2004, 07:36 PM
302 Z28's Avatar
Wow. that is way out the top at $100. A local locksmith who specializes in autos replaced the tumbler in my wifes 97 Tahoe for $35.
Vince
Old 07-22-2004, 01:32 PM
same mthing happened on my 83 s-10 all you have to do is go to autozone and get the new ignition and a steering wheel puller just take off the steering wheel and you can get the rest of it out .
Old 07-26-2004, 11:40 AM
Weimer's Avatar
Kenneth Howard hates you...
Last journal entry: door pics smaller
You will also need a lock-plate compressor. It is very expense for a locksmith to do it....unless you have AAA then its free.
Later,
WEIMER
Old 07-26-2004, 12:05 PM
85citation's Avatar
Life's a small bore.
Last journal entry: The engine's in!!
Has anyone suggested checking the solenoid (if equipped)?
It is located under the steering column cover just below the key switch. I had one fail on a newer GM car, and I spent $400 on locksmiths until I took over and replaced the $25 solenoid.
Hope this helps.
Life is a bore.
It's up to you if it's a small bore or a big bore.
