Please critique this 408 - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-04-2004, 11:58 PM
tornado-tech's Avatar
Am rebuilding my 408 again. It will have Scat internally-balanced 3.75 cast crank, Scat 6" I-beam rods, KB 2-valve flat-tops with C&A 1/16" rings, Comp 230/238 .510/.520 hydraulic roller, Summit Engine Shop prepared Sportsman II's (2.05/1.6, 69cc chambers, 200cc intakes matched to a 1205 gasket), Edelbrock Performer RPM gasket-matched to a 1205 gasket, Demon 750VE carb with 14x6 K&N air cleaner, Petronix Flamethrower HEI that be 12 degrees initial and 20 degrees mechanical, Flowtech Afterburner 1 5/8" headers with 3" Flowmaster 40-series mufflers. Behind this will be a TSI 2800-3200 stall into a turbo 350 turning 4.11 gears and 33" tires. I run mostly 150' mud drags and 200' mud bogs that I did very well last year in pretty well the same combo except with stock S/R torquers w/ bigger springs, Weiand X-celerator and TSI 2200-2400 stall. Also if someone has a desktop dyno, could you run this? The only thing I couldn't find was the flow specs on these heads since they are about 7 years old.
Old 12-05-2004, 12:05 AM
lluciano77's Avatar
Short changed on common sense
That will be very similar to my engine combo.
I would run 18o intial and 16 distributor. That is where I am at with mine. I am at 11:1. If I could, I would run even more timing, but my compression won't allow it.
Old 12-05-2004, 01:03 AM
I was at one time running 18 degree initial and 15 mechanical but in the last post I had about breaking the ring lands, I had a member say: (Your initial timing was probably a big factor, along with the ring gap, in breaking the ring lands. Try 8-12 degrees intital and 20-24 mechanical. It might help the pistons live a little longer). I am planning to gap the rings at .035 instead of the .019 that the 1st Keith Blacks had. I figured if I went with less initial and more mechanical along with a .002 bigger gap than recommended, I could keep this engine alive a lot longer than 9 months and 2500 miles. I have always used forged pistons before and this is my 1st engine with KB's so not that familiar with them. Just don't want to do this again
Old 12-05-2004, 01:28 PM
TurboS10's Avatar
Last wiki edit: Auto Terms and Definitions Used in Modern Engine T... Last photo:
Wiki Edits: 2
Apparently KB recommends a larger than usually gap. I have never run them personally. .035 is alot for an NA engine, but will definately not butt together. I dont think that your timing had anything whatsoever to do with the ring lands breaking UNLESS the engine was detonating at part throttle or something.
Chris
Old 12-05-2004, 03:11 PM
Garbonzo Bojangles's Avatar
Youre confusion is not logical
"Also if someone has a desktop dyno, could you run this?"
Using my non-ported Sportsman II file DD2000 says 398 hp at 4500 and 514 ft-lbs at 2500. The torque curve is almost completely flat until 4000. It says 195 hp and 511 ft-lbs at 2000. It also indicates that the dual plane is better for all RPMs with this combo.
Old 12-05-2004, 03:26 PM
lluciano77's Avatar
That is not the case. The ring land broke because the rings weren't gapped correctly.
If you hear detonation you can reduce the initial a little. But, with moderate compression you can really benefit from higher initial timing.
Old 12-05-2004, 04:35 PM
I used this guide to decide on which ring gap to go: http://kb-silvolite.com/article.php?...=read&A_id=32. I thought the towing at .008 or the mud bog at .009 would both work since I do stress the motor so I took the average at .0085. This figure of .0085 times the bore of 4.165 equals .0354 ring gap. Last year I turned appr 5300rpm for about 45 sec-1 minute in mud bogs going through 24"-36" deep pit. I ran 92 octane with a can of 104 octane boost last year and never heard any denotation and that was with 18 initial and 15 mechanical with no vacuum advance.
Old 12-05-2004, 04:42 PM
lluciano77's Avatar
If you are sure there is no detonation, keep your initial high. I wouldn't run an excessive ring gap. Just run what is recommended.
Don't waste your money on the octane boost any more. It is another "snake oil".
Old 12-05-2004, 05:14 PM
Ok thanks. I will take your advice and run with my original setting of 18 initial and 15 mechanical. Also Lluciano77, what type of fuel do you run with your compression at 11:1 with the KB's you have? I am looking very hard at mixing 92 octane with Sunoco 110 instead of the 104 boost.
