DoubleVision... let's just let him build it how he wants and learn for himself. He's not listening to experience, fact, or reason. He wants that cam, period.
AP72, if you seriously think that a cam with 250 degrees duration at .050 and a 106 LSA is what you call streetable with 31" tires, then you are deluded. That's not what most people call streetable in a 2300-lb stripped Nova with 26" tires and 4.56s. I'm 34, I've built just as many "new" engines as I have old ones, and VE theory is the same regardless. You're right, numbers don't lie, but dynos don't race. You can guess and hope and simulate torque figures, but unless you are a master tuner, you're not going to get anywhere close to the torque that you guess will be down below 3000 rpm. You also probably don't understand that VE below the peak falls off at a much faster rate with anything less than WOT. So all of this torque you speak of in the lower range is ONLY there at WOT. If you've never driven a combo like you talk about on the street, it gets absolutely tiring. Oh... you can also skip the electric fans. They might work on a stock output engine, but you're talking the need for absolutely serious heat, and you'll be doing it while thermally punishing the engine at anything below 3000 RPMs. Even at its most fundamental, you have to see the major mismatch between a cam that is larger than some NASCAR cams, and a factory iron street head that flows 230 cfms.... or do you just not want to look at the numbers in that case. The worst part is, you're going to build this engine out of stubbornness, put it in, then a week later you're going to post the following threads: "350 overheats all the time - I have electric fans" "More mileage from 350 - I'm only getting 4 MPG" "Carb running super rich - It burns my eyes" "Can't get 350 to idle below 1200 - I've already tried 30 degrees initial" "No power brakes - why do I only have 6 inches of vacuum?" "350 not as powerful as I had hoped - I used Vortec heads, but..." Mismatch. Big time. Have fun tuning it. It will take an absolute master. I'm out. |
Okay, I conceeded, I decided to step down a bit on the cam and am going with an ISKY grind.
http://www.iskycams.com/timingchart...._number=201524 which has only 244/248 duration @.050" and .524/.534 lift... I figure buying from Isky is proably a safer route. |
rpm tq hp 2000 355 135 2500 360 170 3000 385 220 3500 435 285 4000 460 350 4500 475 410 5000 475 450 5500 460 480 6000 435 495 6500 390 485 7000 345 465 Retarding the cam timing 2* will make 500 peak hp @6200 and 475 peak tq @5000..... 2* retard and 850 carb will make 505/480. Last edited by techinspector1; 10-01-2008 at 04:34 PM. |
if your off roading my friend did his 79' prospector up with a edelbrock performer cam, 750 carb, and performer intake. the summit cam is .420/440". the heads were magnums converted for a LA block. gears were 4.88's with 31's.
made a powerfull combo. |
I'd do it like a CORR motor, you know...
450cid 820HP Championship Off-Road Racing Small Block Chevy ![]() Really though, a .480ish 218*@.050 on a 112 would be nice. |
Secondly, I WILL be here for the big "told you so." I've been here for years and I plan to stay. Post your numbers after you get it dynoed... or can you just magically predict that like you predict jetting and torque curves? Is your combo terrible? No. Could it be worlds better? Yes. I just have to laugh that the TITLE of your thread is "please critique my cam choice," then you have spent the last three days insulting us and defending your original choice while citing a 4-banger that was a "blast to drive" as your last build. If you think a 4-banger with a 6k torque peak is a blast to drive on the street, then enjoy your overcammed 350 that is built with a no-name Ebay cam. Done. |
Oh and Tech Inspector did a dyno sim of my engine combo... I don't think it looks bad at all- 495 hp, 475 tq... 355 ftlb at 2000 RPM... That's big block territory (not a well built big block, but still impressive for factory heads and NA on pump gas with stock displacement.) I know what you'll say next- its a SIMULATOR... yes it is and its as valid on this combo as any of the other ones. As far as critiquing, I was looking for suggestions on simmilar cams... running something like a 262H cam compared to this one would be as close as running a solid roller... And to risk sounding like a ******* I actaully like arguing about things like this, if nothing else it forces me to reconsider and evaluate my own opinions... even if I decide to still stick to them. |
Hey guy's don't mess with him, he's an ENGINEER. Not to be a @$$hole, but you fit the profile of an engineer (I have worked with TONS of them). No matter what anyone suggests you still think your way is the best, and that's fine because most things are learned through trial and error (unless you heed peoples advice). Just like the Guy who lived next to me with a 327 Chevy that he built, and him & his smart buddies knew that it was over 600 hp. That thing sounded nasty & was pretty cool in his 72 nova, but too bad he got his ***** kicked by my mild 383 in a 3700# 72 Chevy pickup which sounds decent but not radical like his beast (hahahah
).These HotRodders on this forum are very smart and have information that CANNOT be ignored. It pisses me off when someone gives you good advise and you don't listen because you know better. If you are so set on this combo, build it, but don't keep asking for advise and then blatantly turn it down. ![]() (No Offense to any Engineers who aren't bull-headed, I actually am one but a piece of paper with your name on it doesn't give you the right to be stubborn). Last edited by PutPut72; 10-02-2008 at 10:52 AM. |
As far as the bull headed engineer thing, I'm actaully fairly quiet when it comes to giving suggestions, when it comes to work I only speak up when they need the right answer. Seriously though this thing is not meant to set records on the track nor on the mud runs. Its built to be a fun toy to drive. Some people like cruising in an automatic od car with a torque curve as flat as a pool table and an idle speed at 500 RPM... If I wanted that I would buy a diesel. To me running with a 4500 RPM torque peak, banging gears on a stick shift, and the absolute nasty sounding idle that comes with engines like these is a good time. The only thing I'm worried about is running it on 93 octane VS having to switch to E85 because of too much effective compression, and an idle speed over 1,000 RPM (just a number I set as my own standard), and wearing through springs (which with modern designs isn't more than a little more initial capital investment). My effective displacement is still about 276 ci, and compared to a stock 4.3L which comes in around 237 ci I'm still coming out ahead on power with the big cam- even at idle! (I'm comparing it to the largest enigne that came in the S-10 for reference- also the one many people use with stock gearing, auto transmissions, and 30" tires- factory size tire is right around 28-29") Oh yea, effective compression is up too... along with intake and exhaust flow... Are there ways to build engines that idle lower and pull more vacuum and can run on watered down gas- yes, hell you can even buy one from GM for a fairly low price. But where is the fun in that. Lastly, don't blame relying on the numbers as a fault since they don't support your opinion. I understand your opinion- I really do and there's nothing wrong with it. I just don't like being that conservative when its not at all needed. Techinspector posted the numbers- to me they look great. 6,000 RPM hp peak is my idea of ideal for this project. |
if you have a big heavy truck with big heavy tires. thats going to be driven around.
get a 4 bolt main 350 crate HO ,and 4.88 gears with your 31's. Last edited by spinn; 10-02-2008 at 03:53 PM. |
Trust the guys that have built many motors. I have four previous builds with three different cams and and several types of heads and intake and carb setup. If you go too big of a cam you will regret it. Trust me I was there I had a stock 350 with 882 stock heads 76cc chambers with an edelbrock torquer 2 intake with a 600 holly carb for street use. It had around 8.5 to 1 and I used a comp cam 292h with 244/244 @ 50 duration with 501/ 501 lift. Talk about over camming a motor that was bad on my part but that was what I wanted. I did not get what I thought I should of had. This was in a 86 s-10 so it did run fast but man I was getting valve float at 4500 rpm with the stock heads and springs etc.
After I went with way bigger world product heads a bigger dual high rise intake manifold with more compression over 9.3 to one did I get a bigger amount of boost from the cam. You need to get what would be good for street. I right now have a really nice setup with a cam that I don't like to well. I have a comp big mutha thumpr cam wich specs at 243/257 @ 50 with 531/517 lift. That is with a Quickfuel drag racing q-series carb ($650 Retail) with an edelbrock rpm air gap performer intake, Dart iron eagle 200cc heads fully ported with 2.02 1.60 valves with all matching components for the cam. I have estimated 450hp with around 380ftlbs of torque by 6200rpm. I have had nothing but problems with trying to get it tune with my carb. I had a somewhat smaller cam previously and it was a crane powermax. It was a 234/242 @ 50 537/559 lift. That cam did not give me the choppy idle that I like and I switched to the big mutha thumpr cam and it was a big mistake. They both give me good take off and the other perks of hotrodding but the smaller cam gave me way better street manners and mostly likely gave me better hp and torque number cause it was way better for my setup. Trust me be carfull of what you select. Eric |
| 283 cam choice | JohnyR17 | Engine | 5 | 01-08-2008 01:45 PM |
| 383 cam choice | HSR383TPI | Engine | 13 | 11-10-2007 09:11 AM |
| XE274H cam sound like? Heads Choice? Help me decide on combo for chevy 400 | Warrant | Engine | 10 | 03-01-2006 02:58 PM |
| cam choice??? | ko.17 | Engine | 9 | 03-20-2005 12:12 PM |
| Cam choice for new GM 260hp crate motor | Iceberg | Engine | 3 | 02-21-2005 11:03 PM |
