Please Critique Cam and Combo for 383
1969 Chevy C/10 Pickup
2 wheel drive Weight-??? Muncie 4 speed 97 Chevy Hydraulic Roller Block Eagle 5140 3.75 stroker crank -18cc Speed Pro Hyperuetic Pistons Stock-rebuilt PM connecting rods 9.6:1 compression ??? Vortec Heads- all modifications done (springs, etc.) Self-Aligning Full Roller Rockers Vortec Air-Gap RPM Holley 770 or 670 Street Avenger 1 3/4 headers Now for the cam: Cam 1: XR 276 Hydraulic Roller 224/230 110 lobe sep. .502/.510 with a 1.5 ratio rocker Cam 2: XR 282 Hydraulic Roller 230/236 110 lobe sep. .510/.520 with a 1.5 ratio rocker Cam 3: GMPP Hot Cam Hydrualic Roller 218/228 112 lobe sep. .525/.525 with a 1.6 ratio rocker This pickup is going to be driven quite often and I want to feed it the max amount of cam as possible without making it a pain in the butt to drive. Also, I am aware the vortecs drop off flow at about .500 lift, but I figured I could get away with a little more duration with running a 4 speed. How much of a difference will there be between the 110 lobe sep. and the 112 lobe sep. as far as the "rough" idle sounds. I just basically want this thing to run like a beast while still being able to "drive it". Any other cam suggestions or constructive criticism on the combo is appreciated. Thank you. chevy21 |
combo
With a .525 cam your rod bolts are most likely going to hit the cam.
Well lets see hmmmm. First off your trucks pretty heavy and secondly its your daily driver. You neglected to mention the rear gear ratio but no matter.
The hot cam is not a good choice at all. It was designed primarily for an EFI application hence the wide lobe seperation. It will widen the power band on your engine causing the torque curve to be too wide and the engine will feel flat. With the longer stroke and Vortech heads your engine would be more suited with a cam that feeds its desire to build torque. With that said if max HP was your choice then I would run the XR282. Given that fact that your trucks a stick shift and I imagine has a decently high rear end ratio (3.73 or more) I would think it could benefit from the longer duration. My only concern would be the valve springs. If it were me I would compare the specs on the springs you have now with the ones comp cams recommends for that cam. If your springs are weaker I'd replace them with the comp springs. If drivability and Idle quality as well as gas mileage were more of a concern then the XR276 would be the way to go. Being rollers and given the size of your engine both cams will have enough Vaccum at idle for your needs The horsepower you gain from the XR 282 will be more than the amont of torque you will be losing by not using the XR276. So the choice is yours more torque at lower rpms, better idle quality, and gas mileage from the 276 or the added exspense of better valve springs and about 10-15 more HP from the 282. Last edited by Docs91RS; 03-31-2005 at 03:24 PM. |
Even with the smallest of his cam choices the .502 lift will contact a couple of the rods...#1 & #6 cylinders if I remeber right. As with any engine ya have to mock it up first and clearance what needs to be clearanced. .050 is typically enough clearance between rods and cam for most any application.
I would say go with the 276, I think it matches those heads perfectly. It will give you great low and midrange power, which is what you would want in this combo because of the weight, and also, that is what the Vortec heads are good at. The Vortec heads are much better suited to a lower RPM motor.
Adam |
lobe lift
Something I think a lot of you missed on this is the fact that hes looking at running 1.6:1 Rocker Arms on the GM 218/228 cam, which will have the lowest lobe lift of .328".
the 276 cam has a lobe lift of .340" on exhaust side. the 282 cam has a lobe lift of .347" on exhaust side. wasnt aware that Chevy cams had that tight of clearances in them between the cam and rod bolt caps. |
| 406 critique my combo please!!! | HoosierDaddy | Engine | 22 | 02-17-2005 07:53 PM |
| 455 cam head combo | 455c-10 | Engine | 4 | 09-14-2004 08:56 PM |
| opinion needed on a combo, cam advice | Dubz | Engine | 2 | 02-19-2004 01:29 PM |
| Critique my SBC 400 Combo | DTL504 | Engine | 24 | 11-30-2003 05:37 PM |
| Cylinder Head and Cam combo... | redcamaro4spd | Engine | 17 | 06-18-2003 09:23 PM |
