Please critique my setup! I may have mismatched some stuff... - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 05-14-2010, 01:59 PM
F-BIRD'88's Avatar
Yada Yada Yada
I suggest after tuning with the wide band you remove it and install a common narrow band 3-4 wire heated type sensor and simple AFR gauge and use it as a general AFR monitor. (much like a temp or oil pressure idiot light. It will show up any afr changes as you drive. Save the wide band and its expensive/delicate 02 sensor for actual tuning.
The fact that the narrow band type is not exactly 100% accurate at rich ratios/WOT is not critial once the car is correctly tuned. It will faithfully show you if the AFR tuning becomes difference eg weather condition change, vacuum leak failing fuel system, blocked jet, blown power valve etc etc. It will also show ignition faults etc.
As a rule they are much more bullet proof.
Why are you using leaded gas? Leaded gas is illegal on the street in all 50 states and all of Canada. All of the raceing fuel companies sell unleaded high octane racing gas. You do not need lead in the gas. The kids you save may be your own.
www.proracingfuels.com get the lead out....
  #17 (permalink)
Old 05-14-2010, 02:07 PM
How fast is fast enough?
great advice! I run one in every car I currently have. I cut the harness off of a 4 wire O2 sensor from a junkyard and use to to make a connector to the gauge inside the car. if I ever need to sap the O2 sensor its one wrench and unplug the plug- so easy a caveman could do it. Even without a wideban it can help to dial you in.
Ring & Pinion Setup - GM 10-Bolt Help leejoy Transmission - Rearend 3 11-21-2006 07:02 PM
basic air line setup with drawings robs ss Garage - Tools 2 10-11-2006 04:51 PM
Fast Xfi setup info ? x007 Engine 0 04-18-2006 12:58 PM
builders show yer stuff carcrazy1 Hotrodders' Lounge 6 09-17-2003 10:19 PM
Cam lube gray-graphite stuff vs. the red stuff. 78 monte Engine 28 01-23-2003 10:24 PM
