Please? Dust and particles in base coat - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-25-2009, 10:42 AM
Please!!!! Whats the best method to remove any particles in a base coat before top coating. "ChromaBase". I think I"m pulling the filter fibers through el' cheapo furnace filters on the intake side of my booth. I"m using a Gray Scotch brite pad and wondering if I'd be better off very easly dry sanding the area with 600 to remove the nubb's...Thanks for any help, I'm right in the middle of it, Walt
Old 06-25-2009, 10:57 AM
da34guy's Avatar
# 1---- Sand with 600 and recoat B4 you clear
# 2 --- Get rid of the Cheepo filters
Old 06-25-2009, 11:09 AM
Do I need to recoat if there's enough material to hold the color after sanding? I got it looking fairly good. Trying to save another step if possible..Thanks, Filters are history... Walt
Old 06-25-2009, 11:29 AM
da34guy's Avatar
Recoat it to B on the safe side !!!!!!!!!!!!!!!!!!!1
Old 06-25-2009, 01:43 PM
jcclark's Avatar
The Penny Pincher
Last journal entry: Hanging Bumpers
You must recoat base anytime you sand it.
Actually, DuPont says not to sand it but remove it and start over
if their base isn't cleared within 24 hrs.
It's in their tech sheets.
Old 06-25-2009, 02:04 PM
Here's what I'm doing. I build giant scale R/C aircraft for professional pilots that compete all across the country. The pieces shown are Epoxy resin fiberglass and Butyrate. All pieces will be cleared in 7776S. I"m not a pro painter but I do manage to get by. I appreciate the advise, this is about the only reference I have other than the guys at the paint store that seem to have no answer but buy more paint. Thanks guys , I appreciate your time on this, Walt
ps, this is not as critical as what most would do with automotive paints. I'm mainly concern with appearance..
ID:	38967   Click image for larger version
ID:	38968   Click image for larger version
ID:	38969   Click image for larger version
ID:	38970   Click image for larger version
Old 06-26-2009, 10:19 PM
mitmaks's Avatar
Last journal entry: Grille
is the base metallic or solid color? I would put a coat at least after sanding it.
Help: BC with dust particles in it? off2wildblue Body - Exterior 6 05-20-2009 09:16 AM
Clear Coat In Progress mrharris Body - Exterior 2 02-20-2006 09:49 PM
