if its a 73 engine with air gap intake? then there are 4 intake bolts threaded through ears in the head on either side. the othe side of the ears is the crank case. oil will actually wick up the threads of the bolts and leak out on intake. if you dont run a pcv valve the crankcase pressure will be higher and cause this problem to be worse. go to auto parst store and get a tube of non hardening sealer. pretty nasty crap but works like a champ. get holes and bolts clean and reinstall with sealer
